FAQ 200-series FAQ for Modifications, Repairs and Build Threads. Great place for new users to start (1 Viewer)
Status
Not open for further replies.
Romer
fatherofdaughterofromer
Moderator
Centennial, Colorado
The Frequently Asked Questions (FAQ) for the 200/LX570 series tech section continues to be a work in progress. The goal is to have links in the below to other threads and tech articles. By having these linked, instead of pasting the text, the threads will remain live. The live threads can continue to be updated and/or modified for things such as part numbers, adding on additional insight or after a period of time, some follow up information.
These FAQs have been put together by FORUM members. They have put extensive time and research into them. So when you find yourself using them, it would not be a bad thing to send off a thank you.
Again, these will continue to be updated and we will continue to add new ones as we move forward. If you have an idea for a new faq, or would like to take ownership of pulling one together, then don't be shy about it, you'll be helping everyone
Acronyms and Definitions-
Wondering what those Acronyms mean, look here. PM a mod if you see one missing.
Thinking of Buying? - If you are thinking of buying or getting ready to look at an 200 or an LX570, look here for helpful links.
General - General information about this build series
Modifications - Need to start modifying your rig? Look here for what other forum members have done. A good place to start is also the Members Build Threads
Repairs /Maintenance - If you need to perform maintenance to keep your rig running in top shape or find solutions to common repairs, look here
Members Build Thread Links - Best place to find out what you can do to your rig is to learn from others
Event Threads - 200 series Off Road Events
Here is the old FAQ Thread in case that is easier to review
Acronyms and Definitions for FAQ
Common Forum Lingo:
AFAIK - As far as I know
BTW - By the way
FWIW - For What it's worth
FYI - For your information
IIRC- If I recall correctly
IMHO - In my humble opinion
IMO - In my opinion
LMAO - Laughing my @$$ off
LOL - Laugh out loud
OTOH - On the other hand
ROTFLOL - Rolling on the floor laughing out loud
ROTFLMAO - Rolling on the floor laughing my ass off
RTFM - Read the F-ing Manual
RTH- Real Time Help
YMMV - Your methods/mileage may vary
Technical Acronyms:
ABS - Acronym for Anti-lock Braking System. This system uses a computer to control your brakes on your car by applying and releasing your brakes quickly to prevent skidding or sliding from occuring.
ALT - Alternator: power generator for automobiles
ARB - australian 4x4 accessories manufacturer
AT - Automatic Transmission
AT - (tires) All Terrain
ATF - Automatic Transmission fluid
BIRF - Birfield: Found in the front axles of our rigs; they are constant velocity joints that transmit power through variable angles, at constant velocities.
CEL - check engine light, sometimes refers tocode that cuased light that can be read by a code reader
CDL Switch- Center Differential Lock Switch- Switch installed to allow the Center Differential to be locked when the transfer case is in High. The actual Center Differential Lock is in the Transfer Case.
Reference on operation of Center Differential. Diffs and Difflocks for Dummies (George Couyant from www.lcool.org) - Can Purchase CDL from Cdan (Totota) or Slee offroad[/I]
DS- Driver's side
DS: Drive Shaft=shafts that carry power and torque from the engine/tranny/xfer case to the axles.
DC DS=Double Cardan Drive Shaft=a pair of joints in a drive shaft that allows the tube to move in various directions and angularities.
Diffs - Differentials: found in the front and rear axles that consists of gears that transmit equal power and torque even if they rotate at different speeds.
ECT - Electronically Controlled Transmission - allows the engine to rev to a higher rpm before shifting to the next gear. Basically changes the shift points for the transmission. (Best for towing or heavier loads)
EGR = Exhaust Gas Recirculation valve
EWD or WD - Electrical Wiring Diagram, (part of FSM set)
FAQ - Frequently Asked Questions
FHH = Firewall Heater Hose
FSM - Factory Service Manual. The "bible" as published by the manufacturer. Used to guide in repairs
HG - Head Gasket
IAC = Idle Air Control solenoid
JDM- Japan Domestic Market- Refers to items particular to vehicles manufactured and sold in the Japanese market.
Items include but are not limited to:
Power retracting mirrors
Dual air conditioning
Adjustible shocks
Winches
and various cool and some gawdy accessories.
KDSS-kinetic dynamic suspension system
LB/FT - pound feet of torque
LB/IN - pound inches of torque
LHD (Left-Hand Drive): steering wheel on the left side, driving on the right side of the road
LSPV - Load Sensing Proportioning Valve
MAF - Mass air flow sensor
MIL - Malfunction Indicator Light (same as a CEL)
M&S - (tires) Mud and Snow
MT - Manual Transmission
MT - (tires) Mud Terrain
NA - Naturally Aspirated - An engine that is not turbocharged nor supercharged
OBDII - On Board Diagnostics Port available on ALL cars sold in the US 199 and later. Allows a common intercface tool to be connected to read and reset engine fault codes (CEL). Many Autpart stores will read your code for free vs. paying the dealer.
OEM - Original Equipment Manufacturer. (Toyota in this case)
OME - Old Man Emu. An Australian four wheel drive specialty manufacturer that makes all kinds of cool stuff that causes us to empty our billfolds.
PCV Valve - The Positive Crankcase Ventilation valve is an emissions control device that routes unburned crankcase blowby gases back into the intake manifold where they can be reburned.
PI - Propane Injection - Propane is injected into the intake as a diesel catalyst for a more complete burn and additional power
PM - preventive mantenance
PM - private message
PO - Previous owner
POS - Piece of S#1T
PS- Passenger side
PSI - Pounds per square inch - A measure,emt of pressure.
RHD (Right-Hand Drive): steering wheel on the right side, driving on the left side of the road.
RPM - Rotations Per Minute
SC or S/C = Supercharger/Supercharged
SSM - Special Service Materials
SST - Special Service Tools
SUA = Spring under axle. Stock configuration for a Leaf (80's use Coil)Spring Vehicle (vs. SOA previously mentioned).
TB - Throttle Body: controls air flow into engine system in response to gas pedal depression.
TC or T/C = Turbocharger/Turbocharged
TLCA - Toyota Land Cruiser Association (tlca.org) - The Toyota Land Cruiser Association (TLCA) is a 4 wheel drive organization open to all Toyota 4 wheel drive vehicles (except sedan types). This includes all models of Land Cruisers, 4Runners, and 4x4 trucks.
TPS = Throttle Position Sensor, may also be the "kick down" cable
USDS- US driver's side or the left-hand side of the vehicle.
USPS - US passenger side or the right-hand side of the vehicle.
VSV - Vacuum Switching Valve. An electrically controlled valve that diverts vacuum according to the position of the switch.
xfer=Transfer case: sits behind transmission, has front and rear drive shafts coming out of it, and distributes power from the transmission to the front and rear differentials/axles.
General items for the 200/LX570 Series
Have a question you aren't sure where to ask? ask it here in the Stupid Question of the Day thread
General Information:
attachment.php
Compilation of Tools and Spare Parts from forum members
Tires and Wheels:
Electronics:
  • Need to connect your phone via Blue Tooth, here is arich's thread on how to do that
  • 200 series uses LOW Profile Mini Fuses instead of the Mini fuses you might be use to. They look the same from the top but are not. Here are what the correct fuses look like
Matt Gaskins Video on what to pack for 4x4 trips​
Modifications - Many of these are also discussed as part of members Build Threads
Internal
Misc
Electrical:
Replacing Multi- Display with Tesla style Android Unit and Other Head Unit Upgrades
Misc Electrical
Dual Battery Setups
CB Radio Installs
HAM Radio Installs
Optional Power Outlets
Running Electrical Wires
  • Running wires from the engine bay to the cab, poke a hole in one of the larger rubber gromets and run the wire through.
  • Use the area under the plastic trim in the sides to run wire from/to the rear of the vehicle
dsc00882-jpg.1192910
Storage:
ARB Rear Storage Drawers
External
Front Bumpers:
ARB Front Bumpers
TJM Front Bumpers
Other Front Bumpers
Want to add the Black Grill with Toyota Logo, look here
Rear Bumpers:
ARB Rear Bumpers:
Slee Rear Bumper - In Design
Other Rear Bumpers:
Roof Racks
Snorkels
Sliders
  • dtt255s Slee Slider Install Thread
Skid Plates
Lockers, Lower and Upper Control Arms
Lifts/Suspension
RIMs/Wheels
  • Want to run wheel spacers read this first
  • Rockwarrior 17" wheel install thread
  • After Market Wheel Thread
  • Taking Tundra Toyota #75157 wheels and turning them into TRD Pro Wheels. Powdercoat the rims black and buy the TRD Pro Center caps
Before​
capture-jpg.1194168
After​
r2-jpg.1200972
Engine
Fuel
Maintenance
Changing the Cabin Air Filter in the Glove Box
  • Checkout ttrmikes thread on changing the cabin air filter
  • John E Davies thread on the HVAC recirculate door is important with regard to the filter change. It needs to be in the right setting to change and it needs to be closed correctly to work afterwards
Brake Job- Blackford Oakes thread on Brake Job
Changing Engine Oil
Changing Differential Fluid
Changing Oil Filter Cap
Engine
Fuel and Evap System
  • Markusons Fuel Evap Code thread
  • P0453 Evap Code thread
  • TeCKis300 Anatomy of P0456 thread
  • TeCKis300 LRA Tank Breather Fix thread
  • P0441 Thread
  • Romer's thread on removing 12.5 G Aux tank and Evap/Carbon Canister replacement thread
  • TeCKis300 Heat Boiling mitigation thread
  • OTRAMMs Video on 12.5 G Tank install
KDSS
Driveshaft
Repairs
Turn Signals blinking rapidly or not working at all and changing the fuse didnt fix it, see TRD Burglars thread on replacing the Turn/Haz flasher relay
This link is a thread of Common Failures and Repairs compiled by the members. If you are having an issue, look here or the specific threads below
kcjaz thread on how to replace side mirror retract actuator
Click this link for more build threads. Brings up all with the build prefix
rack-jpg.1469860
Events and Picture Threads:
Land Cruiser Destination Club Events
  • 1st annual 200's in Ouray 2015 Thread
  • 2nd Annual 200's in Ouray Thread
  • 3rd Annual 200's in Breckenridge Thread
  • 4th annual LCDC 200 series Destination club in Telluride Thread
Moab Related Events
Select this link to view more Event and Picture Threads
Status
