Here are some error codes, complaints of SDtash and someone named richo7 !
ECD system DTC Code Detection Item
P00AF
Turbocharger/Supercharger Boost Control "A" Module Performance
P00B0
Turbocharger/Supercharger Boost Control "B" Module Performance
P0046
Turbocharger / Supercharger Boost Control Solenoid Circuit Range / Performance
P0047
Turbocharger/Supercharger Boost Control "A" Circuit Low
P0048
Turbocharger/Supercharger Boost Control "A" Circuit High
P004B
Turbocharger/Supercharger Boost Control Solenoid "B" Circuit Range/Performance
P004C
Turbocharger/Supercharger Boost Control Solenoid "B" Circuit Low
P004D
Turbocharger/Supercharger Boost Control Solenoid "B" Circuit High
P0069
MAP Sensor Too High or Too Low
P0087
Fuel Rail / System Pressure - Too Low
P0088
Fuel Rail / System Pressure - Too High
P0093
Fuel System Leak Detected - Large Leak
P0100
Mass or Volume Air Flow Circuit
P0101
Mass or Volume Air Flow Circuit Range / Performance Problem
P0102
Mass or Volume Air Flow Circuit Low Input
P0103
Mass or Volume Air Flow Circuit High Input
P0105
Manifold Absolute Pressure / Barometric Pressure Circuit
P0106
Manifold Absolute Pressure / Barometric Pressure Circuit Range / Performance Problem
P0107
Manifold Absolute Pressure / Barometric Pressure Circuit Low Input
P0108
Manifold Absolute Pressure / Barometric Pressure Circuit High Input
P0110
Intake Air Temperature Circuit
P0112
Intake Air Temperature Circuit Low Input
P0113
Intake Air Temperature Circuit High Input
P0115
Engine Coolant Temperature Circuit
P0116
Engine Coolant Temperature Circuit Range / Performance Problem
P0117
Engine Coolant Temperature Circuit Low Input
P0118
Engine Coolant Temperature Circuit High Input
P0122
Throttle / Pedal Position Sensor / Switch "A" Circuit Low Input
P0123
Throttle / Pedal Position Sensor / Switch "A" Circuit High Input
P0168
Fuel Temperature Too High
P0180
Fuel Temperature Sensor "A" Circuit
P0182
Fuel Temperature Sensor "A" Circuit Low Input
P0183
Fuel Temperature Sensor "A" Circuit High Input
P0190
Fuel Rail Pressure Sensor Circuit
P0192
Fuel Rail Pressure Sensor Circuit Low Input
P0193
Fuel Rail Pressure Sensor Circuit High Input
P0222
Throttle / Pedal Position Sensor / Switch "B" Circuit Low Input
P0223
Throttle / Pedal Position Sensor / Switch "B" Circuit High Input
P0299
Turbocharger / Supercharger Underboost
P0335
Crankshaft Position Sensor "A" Circuit
P0339
Crankshaft Position Sensor "A" Circuit Intermittent
P0340
Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
P0400
Exhaust Gas Recirculation Flow
P0405
Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406
Exhaust Gas Recirculation Sensor "A" Circuit High
P0407
Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408
Exhaust Gas Recirculation Sensor "B" Circuit High
P0488
Exhaust Gas Recirculation Throttle Position Control Range / Performance
P0500
Vehicle Speed Sensor "A"
P0504
Brake Switch "A" / "B" Correlation
P0560
System Voltage
P0606
ECM / PCM Processor
P0607
Control Module Performance
P0617
Starter Relay Circuit High
P0627
Fuel Pump Control Circuit / Open
P062D
Fuel Injector Driver Circuit Performance Bank1
P062E
Fuel Injector Driver Circuit Performance Bank2
P1229
Fuel Pump System
P1238
Injector Malfunction
P1248
Exhaust Gas Recirculation Flow Bank 2
P1251
Turbocharger / Supercharger Overboost Condition (Too High)
P1258
VNT Position Sensor Range/Performance Bank 2 Sensor 1
P1259
VNT Position Sensor Low Bank 2 Sensor 1
P1260
VNT Position Sensor High Bank 2 Sensor 1
P1262
VNT Position Sensor Low Bank 2 Sensor 2
P1263
VNT Position Sensor High Bank 2 Sensor 2
P1495
Intake Air Temperature Sensor 1 Circuit
P1496
Intake Air Temperature Sensor 1 Circuit Low
P1497
Intake Air Temperature Sensor 1 Circuit High
P1601
Injector Correction Circuit Malfunction (EEPROM)
P1611
IC Circuit Malfunction
P2120
Throttle / Pedal Position Sensor / Switch "D" Circuit
P2121
Throttle / Pedal Position Sensor / Switch "D" Circuit Range / Performance
P2122
Throttle / Pedal Position Sensor / Switch "D" Circuit Low Input
P2123
Throttle / Pedal Position Sensor / Switch "D" Circuit High Input
P2125
Throttle / Pedal Position Sensor / Switch "E" Circuit
P2127
Throttle / Pedal Position Sensor / Switch "E" Circuit Low Input
P2128
Throttle / Pedal Position Sensor / Switch "E" Circuit High Input
P2138
Throttle / Pedal Position Sensor / Switch "D" / "E" Voltage Correlation
P213B
Exhaust Gas Recirculation Throttle Position Control (Range / Performance)
P2226
P2228
P2229
P2563
Turbocharger/Supercharger Boost Control Position Sensor "A" Circuit Range/Performance
P2564
Turbocharger/Supercharger Boost Control Position Sensor "A" Circuit Low
P2565
Turbocharger/Supercharger Boost Control Position Sensor "A" Circuit High
P2588
Turbocharger/Supercharger Boost Control Position Sensor "B" Circuit Low
P2589
Turbocharger/Supercharger Boost Control Position Sensor "B" Circuit High
Here are some generic Toyota codes.
P1100 BARO Sensor Circuit malfunction
P1120 Accelerator Pedal Position Sensor Circuit Malfunction
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit Malfunction
P1126 Magnetic Clutch Circuit Malfunction
P1127 ETCS Actuator Power Source Circuit Malfunction
P1128 Throttle Control Motor Lock Malfunction
P1129 Electric Throttle Control System Malfunction
P1130 Air-Fuel Sensor Circuit Range/Performance
P1133 Air-Fuel Sensor Circuit Response Malfunction
P1135 Air-Fuel Sensor Heater Circuit Response Malfunction
P1150 A/F Sensor Circuit Range/Performance Malfunction
P1153 A./F Sensor Circuit Response Malfunction
P1155 A/F Sensor Heater Circuit Malfunction
P1200 Fuel Pump Relay Circuit Malfunction
P1300 Igniter Circuit Malfunction No. 1
P1305 Igniter Circuit Malfunction No. 2 (1998-2000 Land Cruiser, 2000 Celica & Tundra )
P1310 Igniter Circuit Malfunction No. 2 (Except 1998-2000 Land Cruiser, 2000 Celic & Tundra)
P1310 Igniter Circuit Malfunction No. 3 (1998-2000 Land Cruiser, 2000 Celica & Tundra )
P1315 Igniter Circuit Malfunction No. 4 (1998-2000 Land Cruiser, 2000 Celica & Tundra )
P1320 Igniter Circuit Malfunction No. 5 (1998-2000 Land Cruiser & 2000 Tundra )
P1325 Igniter Circuit Malfunction No. 6 (1998-2000 Land Cruiser & 2000 Tundra )
P1330 Igniter Circuit Malfunction No. 7 (1998-2000 Land Cruiser & 2000 Tundra )
P1335 No CKP Sensor Signal Engine Running
P1340 Igniter Circuit Malfunction No. 8 (1998-2000 Land Cruiser & 2000 Tundra )
P1346 VVT Sensor /Camshaft Position Sensor Circuit Range/ Performance Problem (Bank 1)
P1349 VVT System Malfunction
P1400 Sub-Throttle Position Sensor Malfunction
P1401 Sub-Throttle Position Sensor Range/Performance Problem
P1405 Turbo Pressure Sensor Circuit Malfunction
P1406 Turbo Pressure Sensor Range/Performance Problem
P1410 EGR Valve Position Sensor Circuit Malfunction
P1411 EGR Valve Position Sensor Circuit Ranger/Performance
P1500 Starter Signal Circuit Malfunction
P1510 Boost Pressure Control Circuit Malfunction
P1511 Boost Pressure Low Malfunction
P1512 Boost Pressure High Malfunction
P1520 Stop Lamp Switch Signal Malfunction
P1565 Cruise Control Main Switch Circuit Malfunction
P1600 ECM BATT Malfunction
P1605 Knock Control CPU Malfunction
P1630 Traction Control System Malfunction
P1633 ECM Malfunction ECTS Circuit
P1645 Body ECU Malfunction
P1652 IACV Control Circuit Malfunction
P1656 OCV Circuit Malfunction
P1658 Waste Gate Valve Control Circuit Malfunction
P1661 EGR Circuit Malfunction
P1662 EGR By-Pass Valve Control Circuit Malfunction
P1690 OCV Circuit Malfunction
P1692 OCV Open Malfunction
P1693 OCV Closed Malfunction
P1780 PNP Switch Malfunction
P00AF
P00B0
P0046
P0047
P0048
P004B
P004C
P004D
P0069
P0087
P0088
P0093
P0100
P0101
P0102
P0103
P0105
P0106
P0107
P0108
P0110
P0112
P0113
P0115
P0116
P0117
P0118
P0122
P0123
P0168
P0180
P0182
P0183
P0190
P0192
P0193
P0222
P0223
P0299
P0335
P0339
P0340
P0400
P0405
P0406
P0407
P0408
P0488
P0500
P0504
P0560
System Voltage
P0606
ECM / PCM Processor
P0607
P0617
P0627
P062D
P062E
P1229
Fuel Pump System
P1238
P1248
P1251
P1258
P1259
P1260
P1262
P1263
P1495
P1496
P1497
P1601
P1611
P2120
P2121
P2122
P2123
P2125
P2127
P2128
P2138
P213B
P2226
P2228
P2229
P2563
P2564
P2565
P2588
P2589
