Builds Benjamin’s 3D Prints Build (20 Viewers)
Greetings. This is a half build and half promoting thread. I want to document my 3d printed parts/accessories and share the design/fabrication process.
List that shows what is currently available to purchase:
Make 1: Scangauge II Mount for Toyota Land Cruiser 100 Series​
Make 2:​
M2 V1: Rocker Switch Mount for the Lower Right Center Console Panel​
M2 V2: RAM Ball Mount for the Lower Right Center Console Panel​
M2 V2 LEFT: RAM Ball Mount for the Lower Left Center Console Panel​
M2 V3: Magnetic Mic Mount​
Make 3: Scangauge II Mount for Toyota Tacoma Gen 2​
M3 V1 Scangauge II Mount for Toyota Tacoma Gen 2 Type 1​
M3 V2 Scangauge II Mount for Toyota Tacoma Gen 2 Type 2​
M3 V3 Rocker-switch Mount for Toyota Tacoma Gen 2 Type 1​
M3 V4 Rocker-switch Mount for Toyota Tacoma Gen 2 Type 2​
Make 4: Multiple Rock Switches Mount for Toyota Land Cruiser 100 Series​
M4 V1: Six Rocker Switches​
M4 V2: Five Rocker Switches + One Map Light​
M4 V3: Extra Clearance (ARB Style Automotive Rocker Switches)​
M4 V3T: Extra Clearance (Toyota OEM Switches)​
M4 V4: Extra Clearance with one Slot for Dimmer​
Make 5: Scangauge II and Rock Switches Combo Mount for Toyota Land Cruiser 100 Series​
Make 6: Change Pocket Mount​
M6 V1-V5: Change Pocket Mount​
M6 V6: Change Pocket RAM Ball Base Mount​
Make 7: Rear Cooler Switch Hole Mounting Plate​
Make 8: Voltmeter Mount​
Make 9: Kenwood TM-V71A Remote Head Mount​
Make 10: Multi-switch Mount with 12V Outlet or USB Ports​
Make 11: Scangauge II Mount with 12V Outlet or USB Ports​
Make 12: Scangauge II Mount for Mini-Homelink Overhead Console​
Overview of three versions​
M12 V1: Round-up​
M12 V2: Square-off​
M12 V3: Minimalist​
Make 13: Transfer Case Lever Cap​
Make 16: Third Row Ashtray Replacement Panel​
Make 17: Sub-woofer Cover​
Make 18: Third Row Cup Holder Replacement Panel​
Make 19: Fot Light Mount​
Make 19 V1: Fog Light Mount (Rigid D2)​
Make 19 V2: Fog Light Mount (Baja Designs Squadron)​
Make 19 V3: Fog Light Mount (Diode Dynamics SS3)​
Make 21: Overhead LED Replacement​
Make 22: Kenwood TM-D710G Remote Head Mount​
Make 23: YAESU FTM-400XD Mount​
Make 24: EZFix of door switch panel​
Make 25: Door Step (Door Trim Protector)​
Make 26: Wheel cap for Method NV Wheel​
Make 27: Mic Adapter in Rocker-switch Format​
Make 28 V1: Cupholder (Butterfly version) Instruction
Make 28 V2: Cupholder (Non-Butterfly version)​
Make 29: Second-row Cupholders Replacement​
Make 30: Keystone Device Mount in Rocker-switch Format​
Make 33: Center Storage Insert​
Make 34: Hazard/DiffLock Switches Swap Kit​
Make 35: Switch Pros SP-9100 Switch Panel Mount​
M35V1: For regular overhead console​
M35V2: For minilink overhead console​
Make 36: ICOM IC-2730 Mount​
Make 37: Icon Compression/Rebounds Wheel Caps​
Make 40: Small Rocker Switch Mount for Mini-Homelink Overhead Console​
Make 41: RAM Mount Compatible Multi-function Fixture​
Make 42: Dummy Flange​
Make 46: Center Storage Deep Hole Utilization​
Make 50: Hood Struts Safety Clip​
Make 53: TJM T17 Baja Designs S2 Mounting Kit​
Make 59: AUXBEAM Switch Panel Mount​
Make 60: sPOD Switch Panel Mount​
Suggested Project List:
  1. Ashtray mount for rocker switches or USB ports.
  2. Third row AC redirection duct.
  3. A panel to replace the original panel by the left knee.
  4. Rocker switch mount at the center console pocket (See Make 6).
  5. USB charging port at the back of the center console (See Make 7).
  6. Cup holder
  7. Kenwood TM-V71A remote head mount (See Make 9).
  8. Multi-switch mount with 12V outlet (See Make 10).
  9. Scangauge II mount with 12V outlet (See Make 11).
  10. Something in Door Ashtray Slots (by savirc).
  11. Scangauge II mount for the mini HomeLink console (See Make 12).
  12. Third-row Ashtray Panel (See M16 V1).
  13. Third-row Cup Holder Panel (See Make 18).
  14. Subwoofer Panel
  15. Shifter Knob
  16. Morimoto XB universal kit mount ( from @spaber05)
  17. 7in round headlight replacement (from @jay3253)
  18. Variation of M2 to mount a Ram ball (from @geanes and @gregnash) (See M2 V2)
  19. "...my overhead DVD played didn’t work when I bought the truck. I have no idea what could go there, but it would be pretty cool to see what you come up with! Maybe a pocket for CB radio with some lights on the sides? Or maybe just a piece that holds some LEDs that can be wired into the cargo lights so they come on when the doors open? " (from @aaronrules)
  20. something to fill part of the door slot @Otter
  21. A snap on cover that prevents items from blocking or restricting air intake for those with rear A/C @James Bentley
  22. "Ben, I was thinking about the ash tray in front. I know if I pull the tray out my iPhone 11 (pro) will fit. I was wondering if you could fab up a shelf that could have a built in Qi charger. A person could then enter, slide the phone in and it would charge (and if you had wireless CarPlay or whatever the android version is) you’d be coed free and the phone would be out of the way.“ @CBdeJ
i was told you make or can make a mount for an 8” sub. I am trying to replace my speakers and trying to figure out how to mount a bigger sub there.
I want to replace my factory, no nav, stereo on my 98 LC. I was thinking it would be great to switch to a single DIN headunit and use the remaining space for accessories.
What about designing a panel to fill that single DIN slot? Not sure if on top of or below the headunit makes a difference in the design.
I was thinking it would be great to have some RAM mounts in that spot above the headunit.
Similar to this 80 series mod
Hey @BenCC !
Another fog light request, for the Diode Dynamics Elite series fog lamps:
These lamps come with brackets that are a direct replacement on the Tacomas and 4Runners. I like the lights themselves more than the SS3s for my purposes. Any chance of designing a housing to fit these and mount the bracket directly?
Maybe this has been asked, I search the thread with no results, but I have not read through all 2,946 post.
Have you ever been asked or toyed with making the left and right radio trim pieces for 2003-2007 year models? From what I can tell the air vents are removable from that trim piece.
Lots of possibilities there. Could design the lower half of them to compatible with the M2's.
Make 2 V2: Ram Ball Base Mount
1. Overview of the Final Product
This is the final product, M2V2, installed on my truck.
RAM Diamond Ball Base:
Someone else may be interested in a 17mm ball (Garmin standard) that fits the Make 2 Ram mount. Many phone mounts these days use a 17mm ball.
Here is the only 17mm ball I could find with the diamond base. I ordered one and it fits the mount perfectly:
@BenCC still active here? Haven't seen him post on this thread since July. I've sent a couple PMs, maybe they ended up in spam... Looking to get a Make 22.
What about the base for oem roof rack?
No part number or replacement that I’m aware of.
Great thread! Just saw it for the first time.
I have been trying to figure out something to neatly mount a 1/16 DIN panel mount EGT for the diesel 105 now with a 1HD, Mister Blue. The unit is from
@cruisermatt found a great location for the unit in the diesel pickup 70 series:
But I am at a bit of a loss for the 100 series. I'd prefer the console or dash rather than the overhead.
The displays are from Auber Instruments and they make a variety of useful gauges in both 1/16 and 1/32 DIN sizes--commonly used in industrial automation. I'd love to add an accurate digital oil pressure / oil temperature set and an accurate water temp. So ideally the solution would accommodate multiple gauges.
1/16 DIN
1/32 DIN
But I think openings for three 1/16 DIN gauges would work well. They are small, only 48 x 48 x 85mm (1/16 DIN). One of the nice things is that the Aubers' have an alarm output so on the wish list is an additional round opening for a large 'alarm' light, which I think can be ganged together so any of the gauges' alarms would turn it on to attract attention.
