Builds The LF40 Wheeler Build - Twin Turbo & 8 Speed Auto FJ40 (8 Viewers)
It's based on the EMP cover, which I really like the style of.
Oeuverlaunding approved! Engine cover looks like you could pop it off and place over a campfire to cook steaks.
Hey, I've cooked a fair share of stuff on my engine, usually unintentionally, though.
Glad money is going to school😁😁😁😁
Really curious bro see how it turns out. Engine that is. 😁😁😁😁
Everything I seemingly do is expensive, and school doesn't help :rofl:
The hoops ended up around 90° as well.
Readjusted angles.
Anyways, I'm much happier with those angles overall. The panhard and steering is up next, once I get the hellfire knuckles.
I'm hoping to fully dive into wiring while waiting for those knuckles.
Hello Sir, could you get me a measurement from the top of the frame to the top center of your coil over hoop on your front suspension ?
Sure, I'll grab one tomorrow.
Last year's Solid Axle Summit video.
Lots of fab done today.
Motor mounts plas'd out on the table.
All welded.
Engine vanity cover.
Cooler stack.
Intercooler tabs.
Done! It all bolts together, just need to figure out location and mount it once the engine is in.
My condenser will bolt up to the tabs on the upper and lower covers.
Pretty good day today.
I still haven't gotten my harness back yet, but the atlas should be here next week (according to my original ship estimate). I'm keeping my fingers crossed.
-Noodle
I see your intercooler is Mishimoto. Is that who your radiator is from as well? And is it a stock fj40 size?
My radiator is a Frostbite, oversized quite a bit from stock 40 size.
Mounting the LF4
*excited monkey noises*
It fits like it was meant to be.
Full access to run the exhaust, which is a massive win, cause I wasn't sure if that was going to be possible.
I'll build the power steering pump brackets tomorrow.
Remote reservoir is just about perfect, I'll get that mounted as well.
I goofed on the rad mount a bit and ended up a bit wide, so that will get a trimming to fit.
I'm also getting bullied too 😂. Apparently I'm susposed to put those on now.
Very impressive!
More stuff done.
P/S pump bracket done.
It's a wide accessory package.
Cross brace back in.
Radiator in.
That engine looks like it fits absolutely perfect.
looking great. make sure that reservoir hose is as straight shot as possible
It really does. 100% stock engine side motor mounts, and it fits right into a 40 frame. Great depth and length for the trans, it puts it right in the middle of the tunnel. My front driveshaft my actually be shorter than my rear. Probably a first on a 40 :rofl:. It would be absolutely sick of I could pull of the same length front and rear and only carry a single spare for either side, but it probably won't happen.
I'm absolutely stoked with how this swap is going.
