I really wish they had a trail series of that case. I don't need all 300M internals, or gears that big, but those are bouncer and ultra 4 cases. I really love my doubler setup, it's just long. If I could find a cheap atlas, I would totally go for it, but I would much prefer to have the doubler if I have the option. Funny enough, the "short" Atlas 2 is ~11.5" (depending on flange), that Hero case is 12.5" long. Pretty dang similar, besides the internals.
Linking it won't be bad at all. I'll run a double triangulated 4 link, I'll probably build a flat drop skid and mount my lowers there, and add in another bar for my uppers. I'll move my lower fronts then as well. Coilovers are the slightly tricky part. I think I can shove some King 2.0 10" in the wheel wells, may be able to squeak 12"s in there, outside the frame. Really though, I'd rather build more of a faux trailing arm lowers and run shorter coilovers higher up on the arm, so I can get a bit more up-travel and droop out of a better fitting shock. I may need to screw with the rear fame a bit by notching it, but they should clear.
