- Joined
- Jan 6, 2012
- Threads
- 342
- Messages
- 10,979
I would think u would only get side loaded if the heims on the shock got maxed out.
Its tough to sideload something that has a heim joint at both ends.
Ya he probably knows a lot.That's true, but it is also what was recommended to me by Ben @ Filthy Motorsports. I trust him completely when it comes to this. I doubt I'd ever be able to break these, but it is what was recommended to me by the guy who builds them for a living.
Not to sound mean but you're not doing it correctly.If you do a simple force diagram on the shock you will see that at an angle there has to be a force in both the x and y direction. This results in a bending stress on the shaft. Probably also causes more friction forces and heat as well.
Mike
Yes if you use cartesian coordinates system there will be vectors that can across all 3 axes' depending on how you define it.You're right with the joints there's nothing to create a moment. But there are downward and outward components to the force.
Ken
I'm assuming you are using gravity as the Y and length of vehicle as the X and the width of the vehicle as the Z by your description.
The damper/spring assembly will act only in one direction as long as we ignore the friction at the joints on each end.
I don't wanna fill up the thread with this aside but I hope that makes sense.
I can see how you could get a little confused and I don't want to offend anyone here,
Mike
I put a red LED with a home brew diffuser and then used an dimmer to dial it all the way back. It's wired to kick on with the headlights. A little metal sheild prevents me from seeing it directly.
The tiny bit of red ambient lighting is great in the cab at night.
Always love seeing your updates!
Mike
DJ. Did bed line the tub?? I see some texture on the fire wall in your photos.
