Build The LF40 Wheeler Build - Twin Turbo & 8 Speed Auto FJ40
Had a bunch of parts show up this week.
New switches. I have never been a big fan of rockers and I wanted something different. I found these billet 19mm switches, backlit.
They seem to have a nice, tactile click and appear to be very high quality.
Not the cheapest, but I'm excited for them.
New radio showed up. I wanted a clean, somewhat modern look without a big screen or lots of colors. It has all the goodies packed into an order styled box.
I started on the new center console.
Switch panel. I'm not sold on this design, but I'll see how much I like it when it is fully installed.
Started on the skeleton of the rear portion.
Console lid. No idea what this is out of, but it fits well and is the rightish color.
I'm going to be running some A/C ducting to the rear, so I started on the vents. It will also be getting a rear USB charger.
I need to smack the bead roll around a little, it got a bit crooked on me lol.
I wish that I had know about these switches! Where did you get these and what brand are they?
The only thing I don't like about round switches, and this is purely a personal thing. They're impossible to get perfectly straight, and my OCD goes bananas. 🤣
You can fit a lot more control in a lot less space though
Billet Automotive Buttons out of Australia.
I agree. I would have thought these would have a flat spot, but no. Would have made life a lot easier lol.
Wow that is looking awesome
Continuing on the console.
Front panel.
Sides
Digging the look so far.
New switch and cup holder mount.
Switch panel test fit.
Lid is about the perfect height.
I get some bad ideas sometimes lol. Still quite a bit of work ahead, but this should turn out well.
Front panel.
Sides
Fantastic work! If only I had the skills and time haha
I’m surprised you don’t put a Tesla dash in this thing.
Studabacker engine with a Tesla dash 😃. Killer work DJ. Your going to make me want to tear mine all apart now 🤮
I ended up adding 2 switches to the main panel, and my transmission shift stuff right next to the transfer case shifters.
Started on air ducting.
Some filler panels done.
Secondary switch panel.
Liking the look with the new atlas knows.
Need to finish the sides, but that's another weekend.
Power steering cooler showed up as well, another thing to do.
More console work. Trying to get the main panels finished and ready so I can pull it out and get all the finishing work done after work during the week.
Passenger side front panel. This will have the door to get access to the empty space under the console.
Door.
Driver side.
It has cutouts for a shifter mount that sticks out and an OBD II port.
I started digging into the wiring a bit. Picked up a new toy a while ago for this. @sogncab
This thing is super nice. Prints on heat shrink.
And because I am a literal child I added in some special shapes lmao.
It really ties everything together.
Started on all the small finishing panels
Tcase shifters
8l90 shifter.
It's a weird shaped lip around the whole thing.
3rd attempt got it right. It's a strange compounding curve to the back.
Folded up the ring.
I got all the mounting tabs for the sides done as well, but that's boring.
Everything pulled out for final welding and finishing of the little, time consuming bits.
One thing that ended up being easier than the rest was the ducting to the rear of the console.
I used some 2.5" alu tubing scraps to make flanges to bolt on and hook the ducting.
I picked up this mini tubing bead roller a while ago, it does super well on stuff like this.
End result.
Flanges made.
Welded out.
They fit super well and should make this a lot easier.
Tcase shifters
8l90 shifter.
Folded up the ring.
End result.
Flanges made.
Welded out.
They fit supe well and should make this a lot easier.
Awesome fab work. Do you plan on painting it?
