with those teardrop side pipes that would look sweetMost important question.
What color are you painting the cage? I'm voting rattle can chrome.
Go Blue. live a littleGood option there. I'd thing black with all my paneling body color and king anodized blue trim. At least, that is the powdercoating colors I just got lol.
Its going to get some blue for sure. I have enough in the engine bay and would like more color in the cab.Go Blue. live a little
With that type of tube config, you should never drive this without a helmet.
That b pillar bar behind the seat, what is the purpose of it? It's bent so it's not a triangulation bar, and it doesn't look to be in the right place for a harness attachment point.
Idk, I'm an amateur. @matzell weigh in here.
I would rather see straight bars that all meet at a node. I would also like to see another bar above the seats for head protection. I spent two months out of work after a wreck when I was co-driving and we rolled 13 times. The thin alum roof panel let loose and I ended up with a bunch of broken ribs and vertibrae after a rock hit me.With that type of tube config, you should never drive this without a helmet.
This is a light wheeling rig and not a high speed racer. I think it should take a flop pretty good. I would like to see how the bracing works for the A pilar so it does not fold up if it lands on the roof. I hope to see it again at SAS 8 and take a closer look.
What type of tube are you using? Looks like it has a seam in it. HREW?
Gusset on A pillar looks good!Got my front A pillar gussets cut out.
Started on some fuel tank mods for some more space.
I shortened the tank on the drivers side and added some extra space over the hump along with a sump.
On the sump I added a drain. Would have been handy to pull the tank today lol.
Hopefully this tank should be around 20 gal, more than enough with this engine.
Really nice work
Only thing i would have done different is instead of the holes you cut out i would have cut them like a Mollie panel so you could mount things .
What gauge is the alum sheet for tank ? Are you using any insulator under tank ?
