- Thread starter
- #1,401
That is plenty of travel for a full body Land cruiser
Looks like it’s ready for Carnage canyon next month?![]()
I'm good lol. Been on that trail with some buggi bois and it's rough.
Your 40 isn't even the same specie as mine.I let @fjdiesel and @sogncab take it for a spin, so that was fun. It was great to see those guys as well.
Your 40 isn't even the same specie as mine.![]()
What about just having FROR make you a centered FZJ80 rear housing? They have been making new spindles. That way all your brakes, hubs, etc would be the same
I would assume cost would be similar and you would get to keep the FF.
Why would you want a FJ rear you will have to cut everything off. Just have Brian make you a FF rear Housing like i have Use your diff and run Mini truck spindles and Front Range wheel hubs
My rear RCV shafts were 950 if i remember correct. Front Range cuts them to length . I highly recommend going with a FF rear. i can change a Axle shaft in probably 5 min . I had to tow a dead 80 out of the Rubicon and put the axles to the test . and i am on 40s
What about using a rzeppa driveshaft instead?
Teraflex Jeep Wrangler Rear High-Angle Rzeppa CV Driveshaft for 3 to 6-Inch Lift 4612302 (12-18 Jeep Wrangler JK 2-Door) - Free Shipping
FREE SHIPPING! More Flexible Off-Road Performance. After installing any lift kit, it is also highly recommended to replace your factory driveshaft for a more flwww.extremeterrain.com
No. I think they can operate up to their maximum flex since they are constant velocity joints. But you would have to research it. How long is your driveshaft?Interesting concept, fo you know what the operating angles are on that?
