Are you going to try and get fancy with the lower dash pad ? or just fill the holes ? same with the ash tray opening ?
I am going to replace the lower-right dash pad with a custom shorter pad. I may have an upholstery shop do this when I have the rest of the interior done. I plan to keep my 4Runner seats and have them redone in some sort of vinyl material that looks retro and modern.Are you going to try and get fancy with the lower dash pad ? or just fill the holes ? same with the ash tray opening ?
CLEAN!That was a tight fit. I am glad that I got the radio without the CD player. The longer unit would not have fit.
Thanks!CLEAN!
I got it from OTRATTW - The standard in high quality custom rocker switches. - https://www.otrattw.net/ and I used the Contra V switches with the expandable V Series snap in brackets and end caps. It looks even better in person. These are excellent quality.who did you get the switch panel from ?
That turned out really nice .
Thanks! I am super excited to get some paint on it!!That turned out really nice .
Thanks. I already checked that avenue and he doesn’t have this part. He does have the entire switch for around $375. I might attempt to make my own pushrod. It appears that all I need is a piece of aluminum stock, a lathe and a die. What could go wrong. Ha.Toyotamatt for the switch
No way!!! You are amazing. Thank you. I sent you a DM.
