- Thread starter
- #61
I don't recall you using your mirrors much anyway Mike. Didn't I take that picture....?
Times have changed. I didn’t have mirrors for many years after this picture. My dad took that picture.
I've always said there is a solution to every problem, you just have to find that right person. Sounds like you did!A big thank you and plug to Steve’s Transmissions and Gears in the Denver Metro. They built this in under a week and they took the time to chat with Vic at Advanced Adapters to ensure that they were using the best parts for my application.
Google Search
g.co
Mike, I just finished my build with an NV4500 (same Build specs) and an Atlas 4.3. I learned a very hard lesson that I will share, so hopefully you don’t have the same drama. Apparently there is no available transmission output seal that works with mating an atlas To the NV4500. After initial assembly and my first test drive, gear oil started blowing anywhere it could find a passage. Pulled the t-case back out (no fun) and found a distorted output seal. After speaking with Steve At Adanced Adapters, I was told that the seal should have been removed before assembly and I needed to make my own gasket. Steve suggested (Permatex Right Stuff #25228). This Was my first full custom build and just another item on the list of things you are “supposed to know”. Hopefully this saves you from time wasted..A big thank you and plug to Steve’s Transmissions and Gears in the Denver Metro. They built this in under a week and they took the time to chat with Vic at Advanced Adapters to ensure that they were using the best parts for my application.
Google Search
g.co
Thanks for the tip, @TacoMarv. Just to confirm, you have a Dodge tail housing?Mike, I just finished my build with an NV4500 (same Build specs) and an Atlas 4.3. I learned a very hard lesson that I will share, so hopefully you don’t have the same drama. Apparently there is no available transmission output seal that works with mating an atlas To the NV4500. After initial assembly and my first test drive, gear oil started blowing anywhere it could find a passage. Pulled the t-case back out (no fun) and found a distorted output seal. After speaking with Steve At Adanced Adapters, I was told that the seal should have been removed before assembly and I needed to make my own gasket. Steve suggested (Permatex Right Stuff #25228). This Was my first full custom build and just another item on the list of things you are “supposed to know”. Hopefully this saves you from time wasted..
I hear that! This build has been on the books for many years! I’ve owned this Cruiser for 26 years and it’s about time!Very cool project!If my job didn't suck my soul dry and my kids my wallet dry I'd love to tackle a build like this!
I am in need of some help sourcing the pieces to lengthen my frame. Please let me know your ideas. I thought that regular 2x6 1/4 stock would do the job but the frame is an odd size at 2.22 x 5.21 1/5. I am thinking that my best route is to find a wrecked frame with good center sections though I am open to other ideas. Thoughts?
Wanted - Colorado: FJ40 Frame Center Section - https://forum.ih8mud.com/threads/colorado-fj40-frame-center-section.1261084/
If time becomes the issue waiting to find a stock frame for the donor sections, I'm sure a fab shop in your surrounding area could build two c-channels that overlap like the factory frame by bending some plate in a press-break.
Thanks for the answers, @GLTHFJ60 and @EWheeler. I talked to an old friend who owns JW Fabrication and he also recommended the C fabrication route. We will talk later this week to see if he has the equipment to build it.Yup, that's the only option. The mills don't produce stuff that's not dimensional (5", 5.125", 5.25", etc.). Unless you get custom, people just get whatever size is closest to the desired size and send it, so 2.25x5.25", if you can even find that size.
Are you going to have the Aqualu tub on hand before you start the stretch to align body mounts at the rear crossmember, or will you build new body mounts after you get the tub? I'm not sure if they use the factory mounts anywhere? Obviously some of them would be custom due to the stretch....Thanks for shipping the frame section today, @Tank5. I can’t wait to get started!
Great questions! They are going to build the tub to my specification. It won’t be a true FJ-43 replica because I want the body length to be added to the front floor, which hopefully will give more leg room for the forward-facing back seat, plus room to store items.Are you going to have the Aqualu tub on hand before you start the stretch to align body mounts at the rear crossmember, or will you build new body mounts after you get the tub? I'm not sure if they use the factory mounts anywhere? Obviously some of them would be custom due to the stretch....
