Builds Stretched 1-Ton FJ40
I do not think it matters too much on inboarding them, I would put them under the frame for strength. I think you will be fine.
Has anyone used the updated 2016 version of the Triaged link calculator? It has the front and rear in one file and the results are significantly different. My anti-dive (93%) and anti-squat (86%) figures from the 2005 version are nowhere close to that of the 2016 version (21% and 30% respectively). Am I not reading the 2016 diagram appropriately?
I have, and I did notice that. I think it may be a combination of the anti-lift and anti-dive, but I'm not 100% sure. May want to double-check your inputs as well, but I'm assuming you have already done that.
Update: The 2016 version that I found of the original Triaged Calculator was edited by Bush65 (Pirate4x4 name). According to the revision notes, he added calculations for front drive and brake bias, which when set to zero seem to mimic calculations from previous versions of the document. My calculations in the above screenshot are not correct so I will delete that picture so it doesn't confuse anybody who might stumble across it.
I'm moving on to other things as I am happy with my mockup. I'll post the final outputs here once I have the suspension tack welded, which won't be until April/May. I'm taking a break from the Cruiser for a bit.
4-Link suspension
I started working on the Cruiser again. The rear leaf springs and mounts have been removed and it’s ready for the truss.
I made some more progress this weekend. I’m glad that @DangerNoodle talked me into doing the rear suspension now.
The uppers on the rear are going to be 36” in length. The lowers will be somewhere between 40-42” to clear the rear driveshaft.
I learned that this pinion is about one inch off center so I adjusted the upper tower so that it would fit centered on the axle.
Can someone please take a picture of what the body looks like in this area? I want a general reference point for when I weld my shock tower on. I am planning on cutting the body to fit the tower. I just need to know what the body mount area looks like.
Axle truss reminds me of robo cop. What ya climbing with those?
