Builds Stretched 1-Ton FJ40 (6 Viewers)
Looking good. Gonna be a sweet cruiser. The alum roof skin I did was a 4' x 60 " , I made a 2" eyebrow that sticks out front, used the soft top channel to slide little nuts into and then 6 small SS phillips pan heads to hold the front, used U bolts to secure rear at roll cage corners, used a rubber stopper from Ace to glue onto cage above dome lite to create a nice subtle arch in skin. Then I riveted 3/8 alum angle along the sides for a gutter/drip rail, works perfect and the 48" wide is about 2" short of ideal but to comes to 1" past roll cage at top of driver & pass door. A full 4x8 sheet of alum to go all the way back is a few hundred bucks. I did not put anything under it but I did put solar on top.
This sounds cool. Can you link or post a few pictures?
I'll snap some pics, its got a tarp over it now. I am collecting my link stuff, only real decision left is to use partsmike hiems & johhny joints or spend the extra and get tmr stuff for the ends. Parts mike is reasonable cost - $60 for the 1 1/4 hiems with spacers/nut/insert & $55 for the johnny joint with same, only thing i dont like is the 9/16 bolt in the johnny joint vs the 3/4 on the hiems.
I will consider Johnny Joints when mine wear out, or if I get too much feedback from the road. I went with hiems because they came with my mounts from Ruffstuff.
I think there differences in price which equates to the lined hiems vs. non lined, the Ruff Stuff ones are lined and from reports should last quite awhile.
I don’t know what kind of tree you were thinking but this is what I came up with.
Mike, did you need special snap pliers to install the ring at bottom of Radflo's that hold lower seat on ?
you can install without pliers. its getting it off that you will need them
I assumed they were to tight to get on without tools so thats good to know.
