Builds Stretched 1-Ton FJ40 (1 Viewer)
More progress this weekend. It has 7” of possible up travel in the rear. Lower links are just for mock-up and I have the aluminum links ordered from WOD. Thanks for the recommendation on a source for the links, @matzell.
How close do the tires get to rubbing on the shock towers on the rear when flexed ?
Update: this configuration has clearance issues. I will be redoing the rear shock mounts and I will repost with a new threadmark.
Here are some better pictures of the shock mount placement.
Here are a few more at 7” of up travel. This is with the right side at ride height. The axle goes out and forward when one side goes up.
The tire measures about 32 x 10.0.
Do you recall what the WMS-WMS is on your rear axle ?
I’ve moved on to other things. I think that the clips and clamps are intended to replace the gold bracket if needed. I’m using the gold bracket with the following Lokar floor handbrake lever. The only problem is that I don’t have a floor to mount it to. 😂
I have no idea what the round spacer is for. It is going in the spare parts bucket.
Does anyone know what the circled parts are for? They came in my 14bolt emergency brake kit.
Well crud you picked the wrong side to need. That spot is junk on mine
The left side is ok but not sure that would be of any help
