Builds Stretched 1-Ton FJ40 (7 Viewers)
Mike Shull
Let’s go…
Denver, Colorado
This Land Cruiser has been in the family since 1978 and it has gone through multiple builds already. It currently sits on 35s, SOA, power steering, 383, SM 465, and a rear locker. The plan is to stretch it by 14”, replace the engine with a 6.2L LS, then install an NV 4500, Atlas 4, and 1 tons with ARB’s, 5:13 gears, sitting on 40s.
Update on 7/2025. All of the goals described above were achieved, which is a good feeling. I will hopefully get back to Moab next year to snap a current picture in the same spot. Here are a couple of current pictures in the meantime.
Shorten Axle
I found a set of axles that were partially built. I went with the drive terrain from a 1987 K5 military Blazer that had a Dana 60 front and a Corporate 14 bolt rear. I swapped out the rear single wheel hubs for dual wheel hubs to bring my wheel mounting surface (WMS) to 63”. Later I will add disk brakes to the rear.
Next I cut down the left side of the Dana 60 to match the rear 63” WMS and I had a custom 35 spline chrommoly shaft built from Currie Enterprise. The right side already had a chrome moly axle. Minus a seized wheel bearing, these axles look to be in great shape!
Here is a tube I cut the C off and pressed out.
I am not sure but i would think not
I think that you are right, @mr jits. This must be their true beadlock version:
I’m not sure that I like this design. It’s a good thing that I have time to decide. Nice Cruiser, BTW.
I like the look of that wheel. Personally, I'd go the internal beadlock route with a wheel that utilizes replaceable rock rings if I were looking at something like that again. That's totally a personal preference though.
I like where you're going with your rig. Subscribed.
Thanks, @mr jits. I’ll have to look at internal beadlocks. I would like to drive this on the highway for long distances. Given that, would you still prefer the internal beadlocks? Can I run balance beads with this setup?
You can, and from what others have said, they work well with the balance beads (I used airsoft pellets with my beadlocks and they worked great).
The fun begins this morning with the reassembly of the front Dana 60.
Does anyone know what the number means that is stamped into the top of the inner Cs? East Coast Gear Supply did not know. I am guessing that they are the production number. @matzell ?
Thanks for the tip, @matzell. I will do that this afternoon.
Do you have any idea where these c clips go. I thought that they were for the end of the axle shafts but that clip is pictured on top. I have 4 of them and I don’t remember taking them out.
The 3 look like UJoint clips. The single looks like the one for the end of the axle stub shaft.
When I picked up my Yukon's I had leftover clips. Drove me nuts for a couple of hours before I called in to ECGS and they let me know extras are typically provided.
I AM NOT stating this is the case here.
