Builds Benjamin’s 3D Prints Build (11 Viewers)
If you can send me one Tubdra cap, yes
Sweet. please check your inbox and reply w/ your address and I'll send you a Tundra cap.
Greetings. This is a half build and half promoting thread. I want to document my 3d printed parts/accessories and share the design/fabrication process.
List of Makes:
Make 1: Scangauge II Mount for Toyota Land Cruiser 100 Series​
Make 2:​
M2 V1: Rocker Switch Mount for the Lower Right Center Console Panel​
M2 V2: RAM Ball Mount for the Lower Right Center Console Panel​
M2 V2 LEFT: RAM Ball Mount for the Lower Left Center Console Panel​
M2 V3: Magnetic Mic Mount​
Make 3: Scangauge II Mount for Toyota Tacoma Gen 2​
M3 V1 Scangauge II Mount for Toyota Tacoma Gen 2 Type 1​
M3 V2 Scangauge II Mount for Toyota Tacoma Gen 2 Type 2​
M3 V3 Rocker-switch Mount for Toyota Tacoma Gen 2 Type 1​
M3 V4 Rocker-switch Mount for Toyota Tacoma Gen 2 Type 2​
Make 4: Multiple Rock Switches Mount for Toyota Land Cruiser 100 Series​
M4 V1: Six Rocker Switches​
M4 V2: Five Rocker Switches + One Map Light​
M4 V3: Extra Clearance​
M4 V4: Extra Clearance with one Slot for Dimmer​
Make 5: Scangauge II and Rock Switches Combo Mount for Toyota Land Cruiser 100 Series​
Make 6: Change Pocket Mount​
Make 7: Rear Cooler Switch Hole Mounting Plate​
Make 8: Voltmeter Mount​
Make 9: Kenwood TM-V71A Remote Head Mount​
Make 10: Multi-switch Mount with 12V Outlet or USB Ports​
Make 11: Scangauge II Mount with 12V Outlet or USB Ports​
Make 12: Scangauge II Mount for Mini-Homelink Overhead Console​
Overview of three versions​
M12 V1: Round-up​
M12 V2: Square-off​
M12 V3: Minimalist​
Make 13: Transfer Case Lever Cap​
Make 16: Third Row Ashtray Replacement Panel​
Make 17: Sub-woofer Cover​
Make 18: Third Row Cup Holder Replacement Paneld​
Make 21: Overhead LED Replacement​
Make 22: Kenwood TM-D710G Remote Head Mount​
Make 23: YAESU FTM-400XD Mount​
Make 24: EZFix of door switch panel​
Make 25: Door Step (Door Trim Protector)​
Make 26: Wheel cap for Method NV Wheel​
Make 27: Mic Adapter in Rocker-switch Format​
Make 29: Second-row Cupholders Replacement​
Make 30: Keystone Device Mount in Rocker-switch Format​
Make 33: Center Storage Insert​
Make 35: Switch Pros SP-9100 Switch Panel Mount​
Make 36: ICOM IC-2730 Mount​
Suggested Project List:
  1. Ashtray mount for rocker switches or USB ports.
  2. Third row AC redirection duct.
  3. A panel to replace the original panel by the left knee.
  4. Rocker switch mount at the center console pocket (See Make 6).
  5. USB charging port at the back of the center console (See Make 7).
  6. Cup holder
  7. Kenwood TM-V71A remote head mount (See Make 9).
  8. Multi-switch mount with 12V outlet (See Make 10).
  9. Scangauge II mount with 12V outlet (See Make 11).
  10. Something in Door Ashtray Slots (by savirc).
  11. Scangauge II mount for the mini HomeLink console (See Make 12).
  12. Third-row Ashtray Panel (See M16 V1).
  13. Third-row Cup Holder Panel (See Make 18).
  14. Subwoofer Panel
  15. Shifter Knob
  16. Morimoto XB universal kit mount ( from @spaber05)
  17. 7in round headlight replacement (from @jay3253)
  18. Variation of M2 to mount a Ram ball (from @geanes and @gregnash) (See M2 V2)
  19. "...my overhead DVD played didn’t work when I bought the truck. I have no idea what could go there, but it would be pretty cool to see what you come up with! Maybe a pocket for CB radio with some lights on the sides? Or maybe just a piece that holds some LEDs that can be wired into the cargo lights so they come on when the doors open? " (from @aaronrules)
  20. something to fill part of the door slot @Otter
  21. A snap on cover that prevents items from blocking or restricting air intake for those with rear A/C @James Bentley
  22. "Ben, I was thinking about the ash tray in front. I know if I pull the tray out my iPhone 11 (pro) will fit. I was wondering if you could fab up a shelf that could have a built in Qi charger. A person could then enter, slide the phone in and it would charge (and if you had wireless CarPlay or whatever the android version is) you’d be coed free and the phone would be out of the way.“ @CBdeJ
Are these still been made? Came across this via google search joined just to hopefully buy a m4v3 100 series
Yup everything there is still being made by Ben.
Another in for the cup holder.
Might wait for the cup holder and order everything at once or should I order what I want now and get the cup holder when its done? Also I don't see a "make" for the subwoofer cover that you did for @Sargy . What do you recommend @BenCC ?
Shipping's cheap and there's no guarantee that 2021 will even happen. Go for it!
Can anyone confirm if you must remove the "useless" cup holder on the arm rest when utilizing the center console organizer? 06lx
Yes...I can confirm. Check out my post here:
@BenCC I know you did some custom work for the rear sub enclosure but have you done anything for the door speakers? I have 5.25" in all 4 doors but the stock speaker has a non-standard 3 bolt mount that doesn't line up with standard 4 bolt aftermarket speakers. The reason this is a problem is there's a lip around the enclosure that keeps the new speakers from sitting flush in the speaker box. An adapter plate 1/4-3/8" thick would probably do the trick nicely. For now I'm gonna try and see what I can do with MDF. Here's a few pics of what it looks like. (trying to add pics)
Subwooffer cover is only for his setup. If you use same sub, it will fit.
Would you like to mail me the MDF? I can build plastic adapters for you.
The MDF wood spacers? I'm waiting for them to be shipped now. I was hoping you could make something to use instead of the MDF spacers.
