Why do you want to remove it?Whats everyones thoughts on removing the underbody sound deadener?
If the coating is holding up well to the elements and doing a good job of protecting the steel under it I see no reason to remove it especially when trying find something as good as the factory is going to be costly and messy to apply.Well I guess thats why I'm asking the question
I would power wash it good and chase anything that’s not stuck well and recoat with a good undercoating.
Lot of guys use the dry ice method. Let it sit for a little while and hit with a hammer. Should come off in chunks. How you manage to do that when its upside down I'm not sure, maybe just sit the bag on the inside?
I know on the back of mine the undercoat was falling off in places. I pressure washed, let it dry (w/ help from compressed air), ran the wire wheel over everything, then wiped w/ wax and grease remover.
If you can't pressure wash, I would take the compressed air and then wire wheel and then wax and grease remover to everything.
Interesting little addition
Now I must copy you and do that to mine.
HAH! go for it. My thinking was that with the new rockers and floor section, the inside of the B pillar wasn't as tied into the new floor as it could be.. so I added them to give a bit more "pork" to the whole setup..
