Mike Shull
Let’s go…
- Thread starter
- #141
Now I see why the big concern to do the rear while the body is off. I’ve got a bit of work to do back there, which should be a fun project.It's the only one I would do in the rear, as for the front, you can only really do a 3 link unless you run full hydro.
I checked out a 3-link front on an FJ40 that is near my house and I can see why a 4-link front would not be preferable based on clearance to the oil pan. It’s hard to imagine what mine looked like with a drivetrain in it and my LS is a bit more bulky on the bottom end than my old 383. Can you tell me more about how full hydro would help create more space? It is simply because this setup would eliminate the tie rod from behind the axle?
I am just curious as I will most likely do a similar setup as described in the build mentioned a few posts above.
