Are you going to tow the angry behind the target carrier
That would be an awesome sight.
Nice job on the cooler mounting on the angry pig.
looks like it stayed put on your roll over.
Save the beer!
Are you going to tow the angry behind the target carrier?
Jim,
I should have a set in the stash. I could send them out tomorrow. I'll trade for a cold one!![]()
Yes that is still in the back of my mind, I’ve experimented on a few of our long drives with removing the grill and continuing on with the only change being the grill, the temps will drop and average of ~10° that gets me in a safe range to drive at the speeds with the A/C running that I feel is reasonable. With the early grill and early hood (A/C condenser, turbo intercooler before the radiator) I feel I’m limited to about the 2F power levels before my temps climb, looking at the later 55’s with A/C Toyota installed grills with bigger openings and had louvers at the back of the hump hood and my assumption like yours is Toyota had to do this to keep the air velocity up across the radiator.While you want to get more in, it may be an issue trying to pass it through the engine bay. Might want to louver the hood like Ron did.
This is only an issue when driving for extended distances on roads with moderate long hills at 80 miles an hour
Waiting for some of the wiring components to show up for my other pig project thought I’d jump around between the two for a bit.
I’m trying to work on a few known issues now instead of waiting the week before the pig party to get started, as I’ve stated before I can’t get enough air through this grill to keep everything happy on the really hot days so I’d like to mount the later open grill. I’m thinking about taking these parts to get powder coated to save some labor on my side of things but I’m struggling to find the extra set of headlight bezels I had (good chance I gave them away in a big box of pig parts I didn’t think I’d need) anyway if one of you have a set you’re not going to need I would gladly trade you some American freedom bucks for them.
I need the silver outer rings in this photo.
Thanks.
I had no idea Ron had such nice headlights...
More to it than just cutting out the letters.Are you going to try to modify the current grill by relieving the areas in between the letters?
