Build Stretched 1-Ton FJ40
Small gains this weekend! The interior lights and rear marker lights have been wired!
I still have a little bit of wiring to go under the hood. I had an exciting adventure yesterday with the horns. Something happened to my right horn and it shorted out the left horn somehow and fried it. The right horn is sending power through the ground circuit went off, but then switches from power to ground when I press the horn button on the steering wheel—and the right horn works, but sounds like a sick bird. I disconnected both horns and I am getting constant power at the green/white wire and ground at the green/red wire when the horn button is pressed. I suppose that it is time for new horns.
Black oak sent us some lights for Rubithon Raffle and they look good .
I see the marker lights on, are the interior lights on the markers or in their own switch?
I just had that discussion Friday and told my guy I wouldn’t want them on the markers but also wasn’t going to try to fool with a fancy door switch, so a switch on the dash it will be I beleive.
I am very impressed with the quality of the lights and I might also get a light bar from them.
The marker lights are hooked to the factory headlight switch.
I look forward to seeing this at SAS 9 this year.
I’m excited and a little unsure about my decisions to register. Hopefully I can sort out the 4-wheel drive in February, which should give me an idea of how much work that I have ahead of me.
I am looking forward to meeting you and seeing Lynchburg Lemonade. Are you stretching it before the trip?
Hope so! I have been battling a sore ankle for the past 3 months, I got an MRI and go back to doc on Wed. I need to swap gears in my 80 and do final prep for my Moab trip in April, but plan to do a few changes including the stretch to LL before SAS. I will post on the LL thread as I make the transformation.
I hope all went well at the doctors office.
I’m back at it. I remade my air filter mount because the air box was too big and it was pinching my heater hoses. I’m going to attempt to tackle the dryer bracket next since it’s the very last thing that I need to make under the hood, at least for now.
Deep bone bruise at foot bone to leg bones. Should have been off it the past 3 month. I am going to need a few weekends off, at least KOH is on!
I am looking for a set of poly bushings for my front carrier bearing mount like the ones used in the Busted Knuckle Off Road carrier bearing kit (link above). I emailed BKOR to see if they would sell the bushings separately. Do you all have any other leads? I found some bushings on Amazon that are 1/2” ID and 1-1/2 OD and are 1/2” or 1” thick, but they don’t have sleeves and I don’t trust the durability. I can use a DOM bushing if I cut it down. What are other thoughts?
Here’s some bushings that aren’t Amazon, but my real question is about the sleeve…
If you sleeve it (the inside with the bolt I assume?) aren’t you just basically hard mounting then when you compress the bushing to the sleeve? Or am I missing how the Busted Knuckle mount?
I would be a lot easier to cut a sleeve to the right length than a bushing, for me.
I’m still waiting on a shaft from High Angle. He says the carrier bearing will have a spherical OD and housing to absorb flex from engine movement so it can be hard mounted. Others say this will break and I am having trouble seeing why. We use this kind of thing on PTO shafts behind tractors and they last for years. Hopefully it gets here before August which would actually be about a year.
I also saw these on Summit’s website:
I believe that the sleeve prevents the bushing from being crushed, though I’m not entirely certain that this is an issue if I sandwich the bushings between the mount and carrier bearing flange. I’d think that a sleeve would have to go all the way through the hole with a stepped bushing that is partially recessed in the mount like an engine mount to provide ample flex, but I don’t have that much material to work with to do that.
I might try a straight 1-1/2 OD x 1/2” ID 1/2” thick poly bushing without a sleeve from Energy Suspension.
On your setup, I’d wonder if there is a concern about road vibration, especially on dirt roads. I don’t know about my current setup but my SBC/SM465 moved a bit when I traveled down a bumpy road at speed. A tractor would probably never hit that sort of high speeds, but they also don’t have as much give in the suspension so maybe there is just as much movement on a tractor at lower speeds.
The good thing for us both is that this is the front driveline and we can do most everything in the San Juans and surrounding areas in 2-wheel drive. Worst case scenario is that we disengage the front end and get tugged up a few obstacles.
I think you’ll be fine with this.
My concern is that when the engine moves around its axis from torque, the front shaft is on a different plane (the TC sticks out sideways), and while the ujoint flexes it creates a fulcrum point at the bearing, which in my mind needs to flex, and something is going to give, bushings, spherical OD, or a nice billet housing.
It’s just engine torque I’m thinking of.
The tractor thing I was referencing was about the rear power take off shaft, used to drive implements off the back, where one thing moves in relation to another and the bearing has to flex.
I think that spherical bearing may wear out fairly quick in it's housing, but it offers more initial free movement than mounting a rigid bearing on poly.
That is definitely not what the cool kids are doing!!
I’m in.
This work?
Maybe if I redesign my mount. Currently my mount is built from two pieces of 3/8 steel plate and I was thinking of sandwiching bushings between the plate, but I was also considering remaking the bracket altogether using a DOM bushing.
So I’m actually doing driveshaft stuff today as well.
Tom Wood says they can’t put a double Cardon in front of their carrier bearing so I was studying Busted Knuckles stuff, and noticed a fine point you might want to make note of - they have 4 pieces of poly, and the nuts on the bolts are locking nuts - this tells me that the holes the bolts go through may be oversized, with poly on either side of the mount plate and this is how they allow the carrier to tilt when torqued.
Good points. I hadn’t noticed that. I may be crazy but I am thinking about switching to the Busted Knuckle setup and bending my own custom bracket in the H-brake. I will experiment one more time with the WOD mount but I’m not confident that it will be strong enough with bushings in there.
Been poking around as I have time and thinking about your mount.
What do you think the advantage of the Busted Knuckle mount would be, after you already have the WOD? They look similar to me from their videos, just BK welding their amount on first then machining the bearing race area, but as far as mounting goes I don't see much difference.
In watching some vid's it occurred to me that I'm solving my problems with a straight-off-the-transfer case shaft. No angles, just forward projection of the joint. If there is 1. some angle and 2. a slip joint involved, the slip would absorb the engine torque.
All that to ask if you have any angle involved, and if you have a slip joint involved? If so, mount away. (In my opinion, which may be exactly worth what you are paying for it!)
Assuming it does need to flex, can you modify the WOD mount plate and your frame to allow for those poly bushings?
