Builds 79 Aussie BJ55 build (4 Viewers)
Made some progress and finished welding up the floor. I need to get some more abrasives before its ready to prime and seal. I cut some of the rust out of the outer panels on the rear end.. to reveal more rust on the inside! Need to figure out how to approach the removal and replacement..
I also found some original paint.
Started chopping out the rust in prep for patching..
and getting a few offcuts together to build a patch..
Good job! You're making it look easy.
Hah! Thanks!
Dont know about making it look easy... Lets just say im giving it a red hot go..
Looking good mate, slowly getting on top of it all. Im sure it was your 55 I saw some years ago when it was up for sale and thought the body looked pretty straight - never imagined it’d need this much work! Keep it up!
a bit of craft tonight.. before i removed the rust on the passenger side i forgot to get a template of the profile for that corner.. so now i'm using the drivers rear quarter panel as a template then duplicating in reverse for the pax side..
still needs some work and i have the other side cut out just need to put it all together...
those are some real difficult areas to work in. it would have been easy to try to find a downhill path at this juncture, but you turned straight up instead. Good on ya!
those are cool!!!
