Update on the headlight issue, safe to say I have no idea what to troubleshoot next.
Fixes / Troubleshooting
- Confirmed the contacts are clean in the assembly
- Confirmed terminals are clean within the switch
- Confirmed there’s 12V at the plug for the high and low beams with a multimeter
- Checked fuses, all in working order
- Cleaned the terminals under the dashboard
- Replaced dimmer switch wiring harness with new OEM hardware
- Replaced High/Low relay switch below the dash with a new unit
- Inspected Drivers side body ground (Looks good)
Notes:
- When SEALED BEAMS are plugged into the new Toyota H4 harness, I get both HIGH and LOW beams (11.5 volts on the High and 12.5 volts on the low respectively)
- When the H4 lights are plugged In, only Low beams work, which is perplexing
Observations: Might be related?
- The headlights are pulsating slightly, and this corresponds with a slight movement observed in the voltage meter needle on the dash gauge.
Backstory: The body shop killed both deep cycle batteries by repeatedly jumping them while the truck was on "vacation" for a year, and I'm thinking they likely toasted my alternator voltage regulator in the process - why this would cause the high beams not to engage with the H4's I have no idea
Any and all bright ideas are welcome
@CenTXFJ60 @Kleatus @POTATO LAUNCHER @rhah @NookShneer @John McVicker
- here are some photos of the new Dimmer Switch harness for those that are interested
Top: original hardware, bottom new hardware, notice the lack of philips head screws to disassemble and clean
On the right you can see the original wiring harness, and the new harness installed pictured on the left.
The new OEM Dimmer Switch is approximately 5 inches longer than the stock Landcruiser switch
