Build Grey Gardens FJ62LG-PNEA: An idiots guide to resurrecting a high mileage FJ62
Grey Gardens made it home. A few things worth noting:
1. The truck lost power/turned off at speed and popped the efi fuse. It was an original fuse. I checked it after realizing there was no power to the fuel pump and replaced the fuse. It was 10 miles into a 45 mile trip and it didn’t do it again. I’m going to check grounds and make sure the efi relay is fine and I’ll throw the spare on now. What do at @4Cruisers and @red66toy think?
2. I need to replace the main fuel hose from the filler to the tank. It lost about 1/8 of a tank on just that alone.
3. The transmission and t case are coming apart. Lots of backlash and gear noise from the t case. At 291,587 miles it’s not surprising. The botched Rodney flush Got a lot of the contaminated fluid out of the trans, but it still needs help. Thankfully A440f shifted and acted right. I’m amazed.
4. The catalytic converters were nuclear hot and really kept the floor pan warm. I need to get those sorted and fix a small exhaust leak.
It was a great drive. I can see how a properly functioning automatic can be great in one of these, but it’s not for me. 5 speed swap incoming.
It’s running far better now that it got some real heat into it. I can’t wait to see what the bypass oil filter caught.
Interesting on the fuse. I wonder if a wire is rubbing somewhere, but the EFI relay can definitely get nasty inside so its definitely a good one to look at as well.
It passed inspection. I am impressed.
It’s the small details.
1989 texas year of manufacture plates.
Small victories with a lot of effort.
Washed with a foam cannon, degreased it and did a clay bar on the whole truck.
It’s got a lot of dead paint on it but its getting better.
I did a Chemical guys compound in v32 and v34 on one section of the hood. 1 being the worst and where I started; I probably progressed to a 3/10 on the drivers side of the hood just polishing by hand.
The paint is now oxidized but smooth.
When the Milwaukee cordless buffer comes in tomorrow I’ll really hit it hard.
This truck is going to clean up nicely.
I have learned how to completely burn through thin paint.
And by that mistake I was able to figure out what will actually polish and get some light out of it. The second picture is what I can easily get to now.
Can’t wait to keep plugging away at it.
I'm certainly no expert on detailing cars, (my cruiser gets washed once a year at best...), but I think a good paste wax and a gentle buffing after the wax might help get some shine back to those thin and oxidized areas.
It’s getting better.
I’m having huge issues with my m18 Milwaukee batteries and that’s slowing me.
The passengers side is half way done, drivers is improving but needs more elbow grease.
