Builds 1973 FJ 40 Build,Vortec,NV4500,Atlas,Diamond
Question for anyone on the frame.
Configuration is rear leaf's on but no axle up front, just supported on the front crossmember, at the center point, to allow the frame to pivot laterally on this point.
With all the weight on the rig, and the rear shackle angles equal and frame height equal, the front left is ⅜' to ½" lower than the front right. Consequently, if I level the front then the rear is off diagonally by that much.
So a twist in the frame? Don't really know what could be done at this point.
Is this common for that much? I'm wondering how this thing will drive down the road?:frown::frown:
I’m in deep now, no going back
you’ve now officially passed me on your diamond axle build! ill be asking you questions now it seems!!
The bottom pic is of a special tool you can make, It's for installing those inner seals. I'd heard of guys messing them up so decided to make this. It's made from the rear cross member tube, just the right size with a touch of sanding. Fit's right in the seal to get it started.
The other pics just for fun
Front springs mock up today. Getting ready to check angles and dangles. I could get this lower(SOA) by ¼" on the front spring hanger and about ⅜-½" on the shackle hanger, but is it worth it?
Looks good! Let me know if you need an extra helping hand.
Thanks, I'll keep that in mind:) I'm sure you know how it is, much of the time I figure out ways to get things done, but sometimes it's like ya need 3 ½ arms with 6 fingers on each hand:rofl:
Yeah, I know exactly how it is.
U dont want to put the shackle through the frame?
What he said ^^^^^
Well, I have considered it. I was following Chicagos build from a while back. I guess I'm kind of where he was at on this, I had PM'd him about it and he agreed that through the frame was probably the best way, but that in the end it seemed to wheel just fine, he didn't notice anything bad about this set up.
Yes, through the frame would articulate more up and down instead of rearward as shown in my pic. Why is that bad? Other than accounting for the slip joint moving towards TC, simply take that in to consideration. But it's not looking like ride height would be much lower for all the effort, and it would be a big ass hole through the frame, which in reality translates to my unease in my ability to get it right.
The biggest thing would be that offset shackle. This is an FJ60 width axle, so outboarded. So then how would I make that offset inboard side shackle? Not sure anyone in my neck of the woods could bend some ⅜" just right, dunno.
Decisions, decisions:confused:
Convince me
my guess is that you’d be able to move the shackle up about 2 inches which would translate into 1 inch of over all height drop. you’d also have less shackle movement before it impinged in the frame through so you’d need to get your angles just right. i agree about it being worth it. you could probably take out a leaf on your spring with almost the same net effect. it’s still going to move front and back the same amount with articulation. there are offset shackles from ruff stuff though. you could get 5/8 inch movement on each side. don’t know how much you’d need.
