Target carrier (5 Viewers)
Put it on the lift to check the shackle angles before the pig party and thought I should probably change all the fluids at the same time...
Put it on the lift to check the shackle angles before the pig party and thought I should probably change all the fluids at the same time...View attachment 3908100
Maybe we should have a shackle angle contest at PP25? Prizes for:
1) most optimal angle
2) worst angle
3) oblivious award
LOL
I was looking for the correct axle seals on their website a few days ago. They don't list a 55, or at least if they do, I couldn't find it. Assume it's the same seal as a 40 or 60 axle?
Edit: Never mind. Guess it helps to read below the headline sometimes. Google brought right to the spot.
Applications include all 1979-1985 Toyota Hilux 8″ front axles, and all 1969-1/1990 Land Cruiser front axles including FJ40, FJ45, FJ55, FJ60, and FJ62.
Second Edit: Still not seeing a rear for a pig.
I’m pretty sure thats a different shop than what i saw at PP19
Same shop just moved a bunch of junk around when I built the other building..
And I normally crop the pictures so the shop doesn't look so messy..
