Target carrier (1 Viewer)
Did you get some wheels made? I'm trying to get some made that will allow me to run 35x12.5 and fit stock hubcaps. Thanks
@SWRanch go back to somewhere around post #2194 and this where I start going down the road to tall skinny tires and ultimately get a set of US wheels made with the 3.5" back spacing to try them out.
Mounting the hubcaps is an easy deal if you want to ad them.
Inner felt for the tailgate? and how did you fasten the felt?
I retro fit the original clips using a dremel tool. The cutting wheel to make a slot, a burring bit to make an inset hole, and a dental tool create the space to slide the clip in. Used the same method on my doors. Once you get set up and going it doesn’t take long
