PabloCruise
That was me. Next weekend I will be mocking up the brackets. When we get all that done I can mock up the shock towers.
Did you get all of your angles figured out?
I welcome it. Mind is never 100% made up. Everything I try to do on this pig comes with a compromise. Mainly because I don't have unlimited funds to throw at issues.
Thats not actually the body mount, its part of the frame! The body mount sits on top of that piece! I build like you were going to but bridge that entire gap on that frame bracket! And weld in triangular pieces on the outside corners on top of that same bracketmy 20
Megadoomer, I'm not following that, the cam was short on the front?Had a snag with the cam I bought having the gear mounting surface too short.
so I dont know the term but the snout? that the cam gear bolts to was several 1000ths short so the cam gear was pushed against the thrust plate and would not spin. It was the same part number as the stock LM7 but when i measure that part on the cams they were different.Megadoomer, I'm not following that, the cam was short on the front?
Looks sensational!!I took the last 2 days off to work on the Pig. Made some good progress. Engine is done save for the intake and a couple of accessories. Finally got the u-joint for the PS box. Took advice from the interwebs and got the wrong one.
Got the new drag link made and the bugs welded and installed.
You will notice there are shock towers in the above pic. We got them all bent up and welded on. The shock mounts are welded. We would have been able to have it stand on its own but we only had some temporary bolts for mocking.
View attachment 2482127View attachment 2482128
