Builds 79 Aussie BJ55 build (3 Viewers)
True, but this knowledge makes the project much less scary.
Seems like the 80 frame swap is becoming more common. I just met a local guy with a 12HT 60 on an 80 frame - Boss!
I think a big part is seeing how it can be done and using that knowledge to apply to your own situation.. but with anything.lots of research, asking questions and help from the sty will go a long way on a build like this..
I feel like with your pictures anybody who wanted to could put an 80 frame under a Pig!
A lot is to be said for doing it in cardboard first.. i think i'm on my 2nd pack of card so far but its been a surefire way for me to mock things up and then transfer to steel.
Edit to add "anybody with time, money and talent!"
This doesn't look like a project for the faint of heart.
I would like to think money isn't a big part of this build.. I've been trying to keep everything pretty low tech to minimise costs by doing as much as I can... and talent... I think it comes down to using your brain to use what you've got. I'm just lucky the results are sufficiently adequate, but I'd say they are far from shop spec or master fabricator..
Got the rubber body mount seat holes drilled out to 32mm, threw them on with rubbers and bolted them to the body.
i.php
i.php
i.php
i.php
welded up the body mounts and did some more cad for the next stage of these mounts..
i.php
i.php
Factory mounts have a plate on the underside, which I'll also add:
i.php
And I figured because the body mounts hang so far off the chassis I'll add some fish plates to each side of the mount
i.php
i.php
The fish plates should give those mounts the rigidity they need (i hope)..
My shop rental space is inside a machine shop. The owner is always giving me crap about my fab skills.
yes, it’s beef, it’s strong, I get it done, and it works. But damnit, it’s just not that nice looking.
your (and others in this forum) make so much nicer stuff than I do. Cheers to you mate.
Maan so much grinding! Got all my bits cut out and roughed up.. and one mount bottom plste done..
i.php
i.php
the other side isnt going as smoothly..
i.php
Got one body mount welded out and a start on the other one before I ran out of time in the shed today... i think with a bit of a clean up and some paint they will come out good.. and definitely stronger than without the fish plates..
i.php
i.php
i.php
i.php
i.php
i.php
Look beefy!
They tidy up ok and look the goods with a lick of paint.
i.php
i.php
I got one bolted to the body ready to tack onto the chassis but was waiting for the paint to dry on the other first.. also its a bit cold out tonight so that makes the struggle real (2c)
Tacked them onto the chassis and got the body off of jack stands..
i.php
i.php
i.php
Dunno about ride height yet but as there is no springs in there i put the chassis on jack stands thinking about ride height.. loving the clearance just with this much lift but will likely end up with a little more by the time we're all done.
i.php
tacked in place
i.php
i.php
i.php
I've got one more set to do.. they are mostly bent up just need to be finished off.. they sit on the outside of the chassis rail just forward of this mount and are only there because i've used the BJ73 floor..
i.php
Last of the body mounts done..
i.php
Removed the fzj80 engine mounts and gearbox mounts.. just got one gearbox mount to finish removing off the chassis.
Next up is bolting 15bf, h55f and transfer together so i can slot into the 80 chassis and make new engine gearbox mounts..
So i plan to run a 600x300x76 intercooler (https://www.aeroflowperformance.com/af90-1000blk-600-x-300-x-76mm-3-in-out) but I'm not 100% sure it will fit... so out comes the CAD again to make a 600x300x76mm spacer..
i.php
i.php
Running the radiator and shroud from the BJ73 I'll need to use the same radiator mounting setup welded to the 55 front end.. A/C condenser *should* fit in front of the intercooler..
