I mostly finished a Sniper 2300 and Hyperspark installation on my 77. I still need to de-pin the unused wires and clean up the spark plug wires I made. The biggest to do will be a better heat shield on the intake manifold. I bought a bunch of parts from Red Line, but the heat shield didn't work because my intake is from an older model. I will also add some heat protection for the surge tank and more of the fuel lines. I have a temporary one in place on the intake using extra exhaust gasket material I had. I had to break out the welder to build some install parts including modifying the gas pedal, coil mount, mount for the pressure regulator, filter and surge tank. I bought the distributor from
@zerotreedelta and wanted to thank
@knuckle47 for advice along the way. I also had to source a factory air cleaner assembly. I used a RobbMC surge tank and pressure regulator. The dual battery setup and additional fuse panel in my truck made space in the engine bay difficult to find. I first installed the Sniper with my old distributor and coil, put about 40 miles on it and then did the Hyperspark installation. I did a short drive yesterday and will put more miles on today. The hyperspark added some pep off the line and really helped with the Sniper returning to idle more evenly. Before that, it would dip well below 750 and then regulate itself.
