4plus F/R flip kit, booster/master/prop valve, rear disc brake swap, front axle rebuild/knuckle swap.
I love the retro Holley+Downey air cleaner assembly. That's what I put on my dear old '70 FJ40 in the 70's. Also red!4plus F/R flip kit, booster/master/prop valve, rear disc brake swap, front axle rebuild/knuckle swap.
I really need to get my 40 going.4plus F/R flip kit, booster/master/prop valve, rear disc brake swap, front axle rebuild/knuckle swap.
Yes you do!I really need to get my 40 going.
I love old machines. I used remflex gaskets on my inline 250, awesome and took care of leaks. wish i did it earlier. TOYOTA Header/Exhaust Manifold Gasket - https://catalog.remflex.com/TOYOTA_Header_Exhaust_Manifold_Gasket_p/7009a.htmHad similar issue with my JTO header, 3 out of 6 leaked. I had to add a weld then grind down to make them all even.
I’ve got the remflex gasket on the shelf, it’ll definitely be going on, but I can’t bring myself to mounting it until I’ve removed a bunch of the defects.I used remflex gaskets on my inline 250, awesome and took care of leaks. wish i did it earlier. TOYOTA Header/Exhaust Manifold Gasket - https://catalog.remflex.com/TOYOTA_Header_Exhaust_Manifold_Gasket_p/7009a.htm
I'm curious why you ran the exhaust under the frame at the firewall versus above frame like was stock. My 79 has the awful under the frame routing which is stock on 79/80 models with a CAT.
Yeah, not optimal but followed closely to the path of what was there. It’s an 82 that had a cat, so stock routing was over the frame rail (though further up). At some point headers were added and the cat removed. The headers required it to route further back before it crosses over (past the cross member). It still needs to go over the rail, though, because of the stock gas tank location I presume. Candidly, this is not a trail hog anyway (the gx takes the bruises), so I am AOK with it.I'm curious why you ran the exhaust under the frame at the firewall versus above frame like was stock. My 79 has the awful under the frame routing which is stock on 79/80 models with a CAT.
View attachment 3570151View attachment 3570152
Thank you! Appreciate all the knowledge you’ve shared on this forum, it’s been very helpful for my 40 and 62 builds.Nice cruiser.
I received my turn signal lights from CCOT this afternoon and I just couldn’t wait to install them, so I slapped them on..!
My old lights were very old. The color on the bodies were faded and they had developed rust on parts of the bottom mount. They were also not connected correctly as the side ambers would blink along with the front ambers.
The new lights ftom CCOT solved that problem.
The details are what make or break a build. It’s a challenge to stay focused and keep the level up. Some days it’s best to work on something else.@Soberacho Small details are not really so small, they cumulatively make a huge impact. Truck look great
@Jdc1 may appreciate this one…In an episode of the Honeymooners…Ralph is left a fortune by one of his bus passengers. He and Norton are planing for a million dollars. Ed Norton shows up in Ralph’s apartment with a suitcase with strips of paper cut like bills to equal a million dollars. When Ralph confronted him about his dumb idea…Ed replies. “ it’s the small details Ralphy boy “…
Ok @Jdc1 , It ain’t ‘more cowbell’, but another magic moment. In case you’re wondering, Ralph’s fortune is a parrot whose name is ….’fortune’
