What have you done to your Land Cruiser this week? (32 Viewers)
Swapped Bilsteins for the 10 year old OME’s this evening, much smoother on the road. We will see on dirt.
Trail ride last weekend, she preformed 100%
Steering is done. Consist of:
• HJ61 steering box/arm
• BJ75 streering rod w/BJ75 left side steering rod end, on the right side is BJ42 left tie rod end
• original BJ42 tie rod, right side TRE’s hole is reamed a little bit
• Monroe SC-2915 steering stabilizer, mounting hardware (conical pins) is taken from Monroe SC-2946
• homemade shock tower (60 mm further back)
Is there a write up on using the BJ75 rod and rod end a BJ42 TRE? What’s the total length?
I’m gathering what I need to convert to P/S with a Scout II Saginaw box which will need almost exactly the same rod. I’d prefer to use parts that can be ordered over custom fabricated parts.
Just starting to feel better coming off of Coronavirus....
Managed to get a couple stickers stuck, and did some cleaning on the 64.
Here is some: FJ60 Power Steering Conversion for FJ40 while keeping air pump
Mine is now 95 cm (pin to pin). It can be adjusted between ca. 91-99 cm.
Tic tock...
A productive weekend... 1) Replaced the leaking manifold gasket (small exhaust leak on the #1 cylinder exhaust where the gasket had cracked on the outer edge... replaced using OEM ‘yota gasket). 2) Replaced the weatherstripping on all 4 doors.
Took the wife for a drive, “It doesnt sound like a rattle trap anymore...”. But now I’m getting worried that she’s going to want to drive it all the time...🤣🤣
