What have you done to your Land Cruiser this week? (122 Viewers)
I was in need of a confidence booster after my '73 caught on fire, so I decided to install my new upper dash pad from @fjgoober on my '74. It did not disappoint. I had installed his lower pads about a year ago, and was so impressed, I decided to replace my capped upper pad. I even cut the pad to accommodate my dash light. I now have some courage to tackle my crusty, burnt wiring harness off my '73.
Thanks @fjgoober for these damn fine products!
@cruiserkreutz does that have there logo embossed in it above the instrument cluster?
Thanks @fjgoober for these damn fine products!View attachment 1565952 View attachment 1565953
Thank you and the cruiser community.
I am mounting the Aqualu tub. I have a question for you guys.
How much does the body overhang the rear cross member? Or is it flush?
The pics here don't show it very well, but the body is overhanging about a 1/2 in. or so. I can adjust it either way a bit. But this is something I didn't look at prior to taking off the old body.... Thanks for your help.
Well, as difficult & time-consuming as it's been for me, I've (once again) finalized the paint & color scheme of my FJ40 rebuild - which will be maintained as OEM as possible, but has already defaulted as being a restomod.
I've of course gone in circles (and more circles) over the paint scheme, which is never-the-less quite important to me.
Will be DuPont Imron Elite single-stage product of 34031 Army Aircraft Green (now known as Gray-Black) - a color that changes its hue from a greenish-gray to a dark grayish-green, to brownish-taupe, to that of an out-right bronze :
And contrary to a purist desire, I envision strategic portions of the outside of the vehicle will incorporate an ultra-smooth, tinted bedliner of the exact same hue of color. I'm considering utilizing either Raptor or Monstaliner (both are basically the same, and are both UV stable polyurethane with particles of ceramic mixed-in). Rest assure, I'll be practicing on how to thin it & properly apply it, that it be relatively smooth & professionally appearing.
Conversely, both products of LizardSkin will be used on the inside & underside of the vehicle. The inside floorboard LizardSkin (extending to atop the rear wheel wells) will be top coated with a unique, simultaneous mixture of a base/clear of OEM Rustic Green, Dune Beige, and Black (as applied via two two, side-by-side, simultaneously shot paint guns - the paint mixing while traveling through the air). To balance the theme to the outside of the vehicle, aft the two front doors, on the upper portion of the tub, I'll create a 3-inch wide "pinstripe" of this same, mixed three-color combo. This will then extend to the protruding, horizontal-bar of the driver & passenger door (as a natural continuation of the line), where it will then stop - going no further to the engine apron.
I envision such a "pinstripe" will 1) tie the outside of the vehicle to the inside of the vehicle; 2) break-up any notion that the vehicle "is a military vehicle;" and 3) will indirectly complement the Cygnus White roof cap & front bezel.
The LizardSkin on the underside tub, extending up the engine-side firewall, will be top coated with the tinted bedliner.
Within my mind, the envisioned scheme will sport a balance of pleasing form and logical function; will incorporate the OEM colors of Rustic Green, Dune Beige, and on the kick-vent (as a base for my painted winged dog logo), Sky Blue. However, for me, it'll be the artistically painted kick vents, of a winged dog that I've graphically created, that will be "the soul" & central point of the vehicle, which will be my adventure dogger-car, that I one day carry my adventurous dogs.
Along the lines of :
The cosmetics of the resulting vehicle will be held as simple, yet overly nice; and yet, both overly durable & quite doable as an Eastern United States trail-rig. I plan to end-up venturing it out west, as well as, well up into Northwestern Canada too. As a 1979, U.S. spec FJ40 (already modified & previously painted a non-OEM metallic blue-green turquoise by the previous owner), the vehicle, to the best of my ability, will maintain a late 70's feel & sense of spirit. ... The industrial-grade, Aircraft Green paint I'm wishing to use was utilized by the American Army upon their own Cobra attack helicopters, from the mid-70's up until the mid-80's, although as a CARC coated paint.
~Skydog.
Working on doors. The doors were a sickly shade of yellow which was applied with what looked like a roller. Runs and drips and not a flat surface. So I had them sandblasted. The blaster had to dip them in chemicals twice before they could be completely blasted clean.
So I have been smoothing out the surface and treating for rust and after applying some black primer, this is what I have.
There are a couple of dents in the bottom of the doors but I believe that lends character to a 47 year old luxury farm truck so I will simply leave them alone. I will be painting next week and once the repair pieces arrive from SOR and CCOT I can finally install the doors on the 40 and be ready for the hard top to be competed.
1. Adjusted the pin between booster and master, still a little more to go but starting to feel some "help" from booster unit. 2. Found a good body shop to replace some metal on back corners and the rear sill areas this winter.
For the money you’re going to pay that shop you could buy a good mig welder and teach yourself :)
View attachment 1567726 Fully stripped out and sandblasted the front housing, hubs, brake parts. Basically rebuilding the whole thing.
Turned into a major, who would have thought...
Just finished getting everything cleaned, sandblasted (where applicable), and painted for the front axle on my '86 FJ60 project. Sure is a major project. The axle housing and differential have already been installed, tomorrow I'll finish the bulk of the rebuild. Can't wait to get done.
~Skydog.
You kill me. Just paint it purple already.
