- Joined
- Feb 10, 2002
- Threads
- 550
- Messages
- 44,837
- Location
- Canton, Mississippi
- Website
- www.seeandeatms.com
- Thread starter
- #1,421
Where is Pig? I miss seeing his frowny face.
Staying far away from Cowboy
anybody want the oversized or the black, pay for the ride and they are yoursalso got these-corolla i thinkView attachment 2560911they do fit same bolt holesView attachment 2560912
I’ll take them, I’ll hook up with you thanks Donanybody want the oversized or the black, pay for the ride and they are yours
I want to know how this Redhead steering box holds up after you put some miles on it. I've had West Texas Offroad do two boxes for me and they eventually leak as bad as ever.
Do you think the shafts get grooved?
When I ran 12” wide tires with a 3.5” backspace rim my rear tires would rub the inner rear wheel tubs quite a bit on the trails I drive.4” BS wheels
Tires Width is right at 12”
You will be .5” closer with your wheels and might be something to keep an eye on if you drive anything like I do.
I will say that I had stuff that was close when sitting static like you are parked that turned into a fairly significant rub when actually driving on the trail, you’ll get a lot more unfavorable movement with the inertia of a moving vehicle.They are damn close everywhere for sure.
Not saying you’ll have issues on your trails but I would need to make some changes to run the little trails we have out here.
Love that set up. I ordered a single 16x7 smoothie from Tru spoke in So Cal BS at 3.5". Debating the 285/75/16 or 255/85/16.They rub the front shocks for sure. The inner fender just a bit in the back It’s close Both of these spots won’t hurt anything since nothing is sharp. I may get some 1” spacers and see if they still tuck into the fenders and get me off the shock.
My shackles are hitting the anti inversion bar on full stuff and as I’ve discussed before the front shackle angle has flattened out a good bit. I may try to find some shackle that’s a bit longer without the anti inversion stuff.
They still sell that one new! Cruiser Corps stocksNever mind. I have the old skool plate from the bottom.
