Pictures of tires for reference on the fj55
GM Rally Wheels 15x8, BFG ko2s 33x10.50, On stock springs, Some work needs to be be done on the wheels, Center hole needs about 1/8 inch cut bigger and clips, only rubs on front a little when backing out drive way and turning,
@Half Wacked aka Split Pea
Can you post a pic from the side please? I want to see how the 33’s sit in the rear wheel well. Do they tuck inside under articulation?
I think I would strike option 3 from your list. If you're going bias ply then you might as well go with OEM rims or even just throw them on with some tubes on your 16" retaining ring rims.
