Builds Megadoomer Build (2 Viewers)
Forgot to mention that I removed my drive shafts and got the measurements I needed. They are rolling around in the back of my car for me to drop off at the drove line guru. Also exposed a little rot in the driver door. Im going to some panel replacement on that little area. Seems ez nuff to pop my cherry with that.
I have an idea but I may not be ready to announce it yet. I come up with clever plans when I am supposed to be sleeping. Sometimes it helps to fall back asleep when I meticulously go through process in my head. Sometimes it backfires and I just get out of bed and dive deeper in the rabbit hole.
So I brought it up to Steve thinking (maybe hoping) he would shoot it down and say I was high. But he didn't. Which means I may explore deeper. Later tho, it is not mission critical for the beast to roam the planet once again like the cosmos intended.
I dropped off my driveshafts with a driveline guy here. I used him before for some little stuff. He doesn't cut corners and the cost is probably going to reflect that. I ok, because the hillybilly work that was done on them before was probably going to rear it's ugly head at the wrong time. Turns out he is a Toyota guy too.
I was talking to Steve about the rear leaf and suggested we just go 4 link. Then the Driveline guy says that leaf springs are really tough on u-joints, so that's enough for me to go down that road now. Well not now. I have to get the motor running and the front suspension dialed in. Must be ready for some shake downs and the Pig Party.
@DieselFJ I cant send a pic in conversation. This is a pic when I put it in 2013. I added a bit of aluminum on the left side as shown to reach the stock bolts. Right now it it still has the dual electric fan setup attached. I wont need the fans either.
I had the same question but I think it is the axle wrap you get with leafs. I think the fix is to put a track bar like quite a few have done on here.
True - axle wrap IS hard on u-joints. A track bar isn’t too difficult to create for a mind like yours. My ol’ pal RHINO ran SOA for something like 10 years before deciding to install a track bar. Think it had two bushings on the axle side and one on the front where it tied into the t-case cross member/mount.
Link it link it link it, on soa trucks they eat pinions also. Semi. Float a pain to change on the trail. I always set my pinions up a few degrees for small axle wrap under normal load.
Mike
Did I just find the perfect paint?
"Achieving an overwhelming blackness has never been easier!"
Water based???
Holidays, work has been crazy, side work is crazy. Those are my excuses for a crap update. Sunday I messed around with the crossmemember and got it adjusted, cleaned and painted. Also cut my rockers out. I need to clean and prep the metal before putting the 2x4 tubes on. I will be putting 1.5" round tube step. View attachment 2550837View attachment 2550838
...and that's about all you can do with shrimp.
Sweet racer in the background!
Don't kill my vibe with easy fixes to a leaf system. I am already looking at ways to stuff a 4 link back there.
Why not just go 80 frame?
Seriously.
By the time you get through all the measuring, etc, you could just cut a few inches out of an 80 frame and enjoy the fruits of all the Mr T engineer's labors...
Hot Rod City Garage in San Bernardino, CA 909-884-1950. No website.
I don't know if they do stainless but you can see.
My tank was $500 delivered.
these guys have been recommended to me
Got a little time today. I was working alone while Steve is up north visiting a new grandmonkey. I was focusing on the sliders and got the 2x4 cut to length and the step bars bent and cut.
I was poking around the body supports that attach to the rocker area
They are bad, and its a terrible design. They were full of rocks and dirt. I am going to cut them out and make my own. It will be nice to weld them directly to the 2x4. I know I'm adding weight with the sliders but I did drop a few pounds out of the supports.
Looks great! What is the total length on your sliders?
Top of the 2x4 is 69.25". It will have a 3/16 cap on front and rear. I followed the angle of the fender arch and got 22.5 degs in the front and 20 degs in the back. The step is 1.25 dia 5 feet long. I bent the ends at 30 degs. I need more tube for a couple supports in the middle.
