DirtDawg
"It'd be alot cooler if you did"
After all the recent threads, I just figured I would compile everything into one resource thread for people to use and share their upgrades. It is also a great place to ask questions as I have dealt with about every HID setup on the market, and all the questions can be in one thread for future reference. I am not affiliated with The Retrofit Source, but believe they have the best products and customer service on the market, and have been using them for many years with absolutely amazing results. All prices and links are off of their parts, I cannot assure you that an eBay HID kit will not last as long or perform as well. If your a LC guy, there is some info on headlight upgrades at the bottom of this post.
There are several options for upgrading the LX headlights: (I am only posting the worthwhile upgrades as the stock projectors really don't offer good output even with a clear lens and HID upgrade)
NOTE: Light output pictures should not be used as a comparison, different exposure and camera settings vary too much between pictures. All owners/sources for pictures are shown. I do not own any of these pics.
Meh option:
-Factory Hardware
-HID Bulb Conversion
Cost: ~$150 or less
Parts: H1: Morimoto Elite HID System - HID Systems from The Retrofit Source Inc
This is just a basic HID conversion. I suggest a quality kit like linked above over a cheaper amazon/ebay kit. This will be brighter than stock with no modification to your original light housings. IMO this isn't really worth it, I suggest if you don't want to do a full retrofit, at least look into the option below.
Pros:
-More light output than stock
-On the cheaper spectrum of light mods
Cons:
-Possibility of blinding oncoming drivers due to stock projector design.
-Beam gets lost in inclement weather.
-Leaves you wanting more
(@FranceJohnson photo from: LX470 headlight bulbs....help me here.)
Better option:
-Factory Projectors
-2.5" clear lens swap
-H1 HID kit
Write Up: LX470 Projector - TSX-R Lens Swap
Cost: ~$190
Parts: 2.5" : FX-R - Clear Lenses from The Retrofit Source
This is a decent option that offers substantial improvement over the factory halogen setup. It does require you to separate your headlight housings, but for the budget conscious consumer, this might be the best option.
Pros:
-Sharper cutoff and more light intensity than the non-clear lens option.
-Brighter than stock
-Cost
Cons:
-Seperation of housing is required
-Beam still gets lost in rain and bad weather
-Can blind oncoming drivers is "squirrel finders" are not closed
(@Luke111 photo from: New 2006 LX in Virginia)
Best option:
-TSX Projector Retrofit
-D2S HID Kit
-80mm Rubber Caps (dust seal for the rear of the housing as the stock one doesn't fit)
Write Up: Retrofit HID's and TSX Projectors into my LX470
More pictures and info: Lexie the Comfort Cruiser
Cost: ~$350
Parts: D2S: Morimoto Elite HID System - HID Systems from The Retrofit Source Inc
Low Beam: Acura TSX - HID Projectors from The Retrofit Source
Rubber Housing Caps - Custom Headlight Build Materials from The Retrofit Source
This is the best option out there and what I am currently running. It provides a clean cutoff with bright, evenly distributed light while (when properly adjusted) doesn't blind oncoming drivers. My windshield is tinted 60% and the light output is still nothing less than stellar. There is an optional clear lens upgrade for the TSX projector, but I preferred the stock lens (2.5" : TSX-R - Clear Lenses from The Retrofit Source).
Pros:
-Bright, full, useable light output
-Easy to source
-Easy to retrofit
-Wide beam pattern
Cons:
-More expensive
-Requires irreversible modification of original projector (not a bad thing)
-More work intensive
(@deanfun photo from: Retrofit HID's and TSX Projectors into my LX470)
Other Best Option:
-SC430 Projectors
-HID Kit
Write Up/info:Lexus LX470 retrofitted with Lexus SC430 projectors.
Cost: ?
This is an equal upgrade to the TSX projectors, however the SC430 projectors have proven to be almost impossible to find by myself and other forum members. It is however an easier swap, but still requires you to cut the original projector.
Pros:
-Easy to retrofit
-Wide beam pattern
Cons:
-Same as TSX Cons
-Harder to source over the TSX projector
(@silverbullitt photo from: Lexus LX470 retrofitted with Lexus SC430 projectors.)
All the need to know info:
About projectors: TRS 2016 Projectors Tech
About bulbs: TRS 2016 Bulbs Tech
About bulb color: Which HID / LED Headlights color is the brightest ? Is White more brighter or Blue ?
About ballasts: TRS 2016 Ballasts Tech
About clear lenses: TRS 2016 Clear Lenses Tech
Additional parts/suggestions:
I suggest that if you are going to separate your housings, to buy some extra butyl to make sure you seal the housings back up well. Butyl: Morimoto RetroRubber Butyl Glue - Custom Headlight Build Materials From The Retrofit Source
Additional threads:
LX470 Headlight Alternate Experience?
LX 470 City Slicker Upgrades
LX470 Headlight Bulb Upgrade- Pics
For the LC guys that came here searching for answers:
If interested in upgrading bulbs only, I would suggest HIR bulbs. I STRONGLY SUGGEST TO NOT PUT HIDS IN YOUR STOCK HOUSINGS. The stock housings are not made for HID bulbs and you WILL blind oncoming traffic. If interested in the best option, a retrofit is the hands down the most light output. LC upgrades discussed more here: Headlight Upgrade Options
I am sure I'm missing some stuff and will continue to update as more info is provided. I also do retrofits as a side business, but it is usually only to people local to me. However if you are interested in a retrofit but don't have the time, pm me.
Meh option:
-Factory Hardware
Cost: ~$150 or less
Pros:
Cons:
Better option:
-Factory Projectors
-H1 HID kit
Cost: ~$190
Pros:
-Cost
Cons:
Best option:
-D2S HID Kit
Cost: ~$350
Pros:
-Easy to source
-Easy to retrofit
-Wide beam pattern
Cons:
-More expensive
Other Best Option:
-SC430 Projectors
-HID Kit
Cost: ?
Pros:
-Easy to retrofit
-Wide beam pattern
Cons:
-Same as TSX Cons
Additional threads:
