Sounds good love the progress
Nice job @RUSH55 !!!Not sure if you guys have heard of a charcoal canister called “The Vapor Trapper”, but I picked one up to vent the fumes through. The discharge side vents in behind the fuel door, via the J Mack vent method.
Beautiful work; especially using the Swagelok type hose fittings.
So there's no purge on that charcoal canister. Looks like you just replace the media periodically?
Thanks guys!Nice job @RUSH55 !!!
Mine is way less Boujee but very similar, 2” PVC (yes it has good resistance to fuel) cut to length with some standard caps drilled and tapped for 3/8” NPT fittings.
Slip one of these 2” screens McMaster-Carr - https://www.mcmaster.com/9317T81/ in each cap before you tap them on and fill with standard fish aquarium activated charcoal.
Obviously the unit Rush bought is very nice but if you have a smaller budget the PVC will do the same thing.
Nice work! Can you post a source for the filter fitting above?Not sure if you guys have heard of a charcoal canister called “The Vapor Trapper”, but I picked one up to vent the fumes through. The discharge side vents in behind the fuel door, via the J Mack vent method.
Source for the filter fitting above?Nice work! Can you post a source for the filter fitting above?
Sorry, I meant the little brass filter in the -6ORBSource for the filter fitting above?
The filter website is posted above, if that’s what you mean. The fittings coming out of each end are 6ORB male to 6AN male, and the hose fittings are 6AN to 3/8” barb, all of which came off of eBay.
That is just an 1/8” NPT sintered bronze breather. Also off of eBay.Sorry, I meant the little brass filter in the -6ORB
Can I use this on my BONGNot sure if you guys have heard of a charcoal canister called “The Vapor Trapper”, but I picked one up to vent the fumes through. The discharge side vents in behind the fuel door, via the J Mack vent method.
Vapor Trapper | Charcoal Canister
The Vapor Trapper a high-quality billet aluminum charcoal canister, designed to successfully eliminate fuel odors. Engineered for both classic and modern vehicles, our product supports cleaner emissions and an odor-free driving experience. Shop now. Made in the USA.www.vaportrapper.com
Also modified the fuel neck vent to 10AN
