Builds Fly By Night (16 Viewers)
All day long working on this and not sure if there’s been any progress made.
Wasn’t totally satisfied with how tight the 1-1/2” side runners for the interior rack were fitting against the roofline. Brainstormed the idea of using a piece of 2x6 lumber as a template. Before running to the hardware store, I found some dents along the roof line that I thought could possibly be causing issues. Been wanting to try that method with the rawhide mallet ever since seeing that video, but still haven’t bought one, or a sandbag dolly. Made a sandbag out of blasting media, a gallon zip-lock and some duct tape. Was able to reduce the dents pretty good with the bag and a regular body hammer, but still needs some work.
Anyways, got some 2x6 and cut to 93”, formed it to fit tight against the roof then rolled another length of 1-1/2” square tube. Got it to fit well against the 2x6 template, except for the last inch or so of the rear, which curves so dramatically that the roller can’t make the radius. After screwing around trying to get it to bend enough, I just pie-cut and welded the f**ker and called it good. Go to trial fit it against the roof. Gap - almost all the way across, which is interesting, but doesn’t make me want to strip naked and dance in the street. Also beginning to see why Scrappy’s mounts are angled instead of flat against the, the, you know, the thing. Upper... thing, stuff, sheetmetal section between the top of the door frame and roof line.
Anyways, don’t get to mess with it tomorrow, have to go work. Want to get the outer perimeter of 1-1/2” tube work done so I can send X’s dies back so he doesn’t think I’m trying to keep them (soon man!).
Hat’s off to him and Scraps for pulling this job off already - what a PITA! Why must I be so damned impressionable?!!
Well, it sounds like it’ll be very satisfying when you get done! :beer:
#progress
Got the passenger side runner’s mounts welded on as well as the mounts in the body welded solid. Angled 3 out of 4 a few degrees so that the plates would tie in directly to the underside corner edge of the tubing.
Got a start on the driver side with getting everything tacked.
Still wondering how cooperative the rack will be and want to drop out and go in once it’s all assembled🤷🏻‍♂️
#progress
Most excellent!!!
Yeah... most non-existent monsoon I can remember, ever.
So I push the frame outside to do some paint stripping and the clouds start rolling in. Must smell bare iron like sharks on a single drop of blood.
No clouds in forecast until tomorrow ...
More like,
“God, why are you trying to kill me?” - Welder
i saw 108 on the car temperature indicator yesterday, the high here tomorrow is supposed to be 38.
Rain is supposed to start tonight and switch over to snow - I’ll take it!
We have a fire about 50 miles N & W of us that grew from >20k acres to >60k acres over the weekend.
The sky looks like when we had the total eclipse.
I washed my woman’s 470 this morning, here’s the hood an hour later:
Using these stripper discs from Home Depot to clear off the factory paint on the large flat areas. Gone through 3 of them at $9 and change a piece, and may have a solid 30% of the frame cleaned. I’ll go sandblaster to get to the inaccessible areas. Want to get this frame painted soon.
And then here are a few random Labor Day Az sunset pics for your viewing pleasure.🙂
And BTW, what are these captured nuts on the the top side of this crossmember for? Don’t think I’ve ever had anything attached to them...
