Damn that sounds nice. Great work.
Gorgeous snake!!! Bummer those are the super venomous ones.Sticking to my plan. Wanted to hit the doors with Epoxy but I'm running out of daylight. Don't want to risk bugs this time of day. Will shoot it in the AM and then primer surfacer after lunch. Block it tomorrow night and base/clear on Friday. This is just the inside of the doors. Will work on the mechanicals for a few weeks and shoot the outside of the doors after the inside sets up. Have most of the bodywork/sanding done on the outside so I'll get to the paint process pretty quick. Ever since we got the new motor in that's all I can think about. Painting is usually my favorite thing but not now. Glad the doors are the last of it. Oh...and I had a bit of an issue with the t-case leaking. Had some great input from the experts on a separate thread. Some gray epoxy and a lower mileage (75k) flange and I hope I've solved the problem. And the pretty Coral snake decided it wanted to hang outside the shop. Don't see too many of these. 2nd one in 11 years (thankfully). View attachment 1435302View attachment 1435303View attachment 1435304View attachment 1435305View attachment 1435306
How'd you do it? Shovel to the neck?Yep. Deader than dead![]()
Thanks Ryan. Looking forward to the day I get to enjoy this truck as you can understand. In fact, I was thinking about your build the other day. I decided that I'm going to swap out my evaporator since I have the dash out. I've had a brand new one on the shelf so it makes sense to do it at this point. Since you've been into the internals of the plenum, is there a kit I can buy to reseal everything or did you reuse the original stuff? Or is it a case of sourcing parts individually?Looking good Jim
Pictures when you have time would be great.That sounds like a lot of technical terms !!!! (plenum) I think you are talking about all of the flapper doors that direct the air. If so, I went to a local foam and upholstery shop and got some stuff that was close to the same thickness and cut to fit. For the seal around a lot of the openings, I went to Napa and get some rolls of door seal gaskets that again the same thickness and cut/glued all of it back in. I have some of the packages of the door seal material if you want me to send you a text with that info
