What have you done to your Land Cruiser this week? (34 Viewers)
and 1 of it outside
Been putting off a valve adjustment so I finally pulled the trigger today. Every one was PERFECT! I've owned this '75 40 since 1996 and check the valves once/year. Only once did I have an exaust valve that was slightly tight, and an intake that was slightly loose. Oh well, I have a new gasket and peace of mind. Just curious about how often you guys adjust the valves on your rig? Also , had a hard time keeping the valve cover gasket in place this time while installing the valve cover. Is there some secret I'm missing? Cleaned spark plugs, checked the points and checked timing all was OK.
Test fit my new chains for next weekends drive. The test fit is on 235/85 16 which I know will not clear the front steering linkage without spacers. The actual tires are 7.50 r16's. hardened square links 5.5mm.
I just realized that they are on inside out after I took the pics.
There is a yearly snow drive- 3 day event- very unofficial. Just show up if your in the know kind of a thing. I couldn't go last year so this will be my first time. Off to Nagano next weekend to climb the mountains.
Pete
So jealous. :flipoff2:
Matsumoto-jo is one of the coolest things I've ever seen. Stop by there if you've never been.
My oldest daughter and I have been tossing around the idea of Ozzfest in Tokyo in May.
Wish me luck all, I'm going out to weld these up:
attachment.php
attachment.php
EDDY
O.K. Lets see the morning after photos
Broke an Easy-Out trying to remove a rusty bolt in my exhaust manifold!!!
Any suggestions?
Get a stick welder. Build up the weld in the block so you can weld a bolt onto it. Back it out - the heat will also loosen the broken stud/bolt. Just did the same with mine, but without the EasyOut!
I wanted to do the sill with adhesives anyway, so I got my wish.
This is a lot more like how a new car body would be put together and the adhesives will keep water from between the metal layers. I repaired my bib this way on my '78 too.
The rusty floor is pretty solid other than just a couple little spots, so I'm repairing those and I'm going to coat it with something, maybe color-matched Monstaliner.
I added a 1.5"x1/8" steel 'shelf' to hold up the floor. JB Weld and rivets on this side.
attachment.php
I didn't get a picture with that piece attached but not yet installed. I rushed through painting it so I could get it installed before dark. Here it is with just the sill brace installed. You can see the rivets where the other piece was attached underneath. There is FIPG between the floor and the added steel to keep any noise or water out. I decided I didn't need rivets on this side.
attachment.php
Then I stuck on the sill with FIPG. It will still get tacked at the holes and welded to the sides of the tub where they intersect and the body panels when they get welded up. I'm ordering my welder today. Tired of counting on others for welding.
attachment.php
Are you really sure you want that hi-lift jack aimed at the windhshield that way? It looks like it could be deadly for a passenger during an accident. :frown:
Tool brackets.
My wife drove it to work today. We're pretty sure her car (Civic) blew a head gasket. It's got 210K and although I can't see any oil in the coolant, the coolant overflow is got this nasty black sludge all over it, and her heater core started leaking really bad (pressurized coolant?)
She's going to be driving her truck until we can afford a new car. We've been thinking about buying an FJ80 or 100 sooooo... maybe it's sooner then later.
Installed my 40 series tacho yesterday. Cutting the huge hole in my baby's dash was pretty nerve racking. All I could think of was sorry, sorry, sorry, while hacking into her with my 4" grinder:crybaby:
Even though this is an FJ40 the five pin plug for the diesel tacho wiring was sitting there looking at me after I cut the hole. The only wiring I had to do was a single wire from the sensor in the side of the 12HT bellhousing to the spare wiring loom connector in the engine bay. Works great :bounce:. Don't you just love Mr Toyota sometimes.
Restored all the heater components and fixed parking brake. Set on stands and took wheels off for brake restore.
I got my new frame to a point were I needed to set the body on to finish the fab work.
[/IMG]
I then built a roll around table for the frame and body to sit on. I can now fab the body mounts, mock up the rest of the tubing and supports.
[/IMG]
Pulled everything off the firewall so I can clean it up.
[/IMG]
I cut the welds off the dash, and pulled the dash out. I am gonna hide tubing behind the dash so need access for now.
[/IMG]
Set the hood on to do some measuring and a little planning.
[/IMG]
