What have you done to your Land Cruiser this week? (84 Viewers)
my 40
Project high-mount power steering and alternator (ala 60 series) completed!
-got the power steering and alternator belt for my 2F (OEM spec)
-moved the alternator from lower driver side mount to upper passenger side mount
-removed the alternator brackt and installed the air pump bracket on lower drivers side (no engine mount removal necessary)
-installed gutted & refurbished air pump and belt to lower driver side mount as water pump tensioner
-f*@$in' struggled with the OEM spec belt for 1 hour before giving up
-spliced in the alternator wires (off spare harness) into the passenger side harness - here I was able to pop out the couplers in the plug for the voltage regulator and plug the spare harness parts right in, I used the post mount for the battery/fusible link to alternator wire for the new alternator wire, and just had to solder in the ground)
-taped up the old alternator plugs for use with a second alternator should I install one)
-traded the OEM spec 1525 belt for a 1550 and still struggled to get it on, but did.
-burped the P/S system
-drove and checked for squeals and leaks and oversights (none :-)
Bad news is the missus can once again drive it :-(
still working on my gauge cluster swap. I got the blinkers and hi beam wired in. debating on where to tie in for the 12v hot and grnd. That and I have the sending unit for the fuel gauge to tie in and it's done. It shouldn't take 2 weeks to do this but I've torn it apart twice after changing my mind on a couple of things.
finally got my back glass mounted
changed my rear diff fluid
2 steps closer to making her my DD
next is change tranny and t-case fluid
then rattle can paint job and work on sealing up my top
painted the last few bits on the motor and put back together
( still need to do the starter )
Popped on the dope decals from Shane ( thanks man! )
OOOOH man is that sweet. Outstanding job done so far. She looks good without any clothes on. :cheers:
painted rocker panels and removed the old rusty smitty built running boards!! :cool:
Installed the body, aux. gas tank, fill tube, front end, buffed the body and plan on buffing it again a few times Monday and install the cage. Wednesday need to spray red on the doors, windshield top of hood and rear hatch.
Well after about a month of off and on work I did finally finish my homemade roof rack.
I wanted one that would work with hard top AND the soft top.
Sure wasn't going to spend close to 1K for one from SOR and it only worked with a soft top.
I installed a new set of spark plug wires. I also tore-down, cleaned, and rebuilt the new to me Warn hubs that are going on to replace the destroyed Selectros.
Before and after pic's: got rid of the ghetto PS fluid cooler that came with the free PS parts and upgraded it to a mid-90's suburban tranny cooler. That was a precursor to doing the onboard air compressor. Hoping to have that project finished up next weekend :).
I cleaned it and removed the soft top since the unbearable heat and humidity are finally over and I can drive it topless again. Next I want to modify the soft top bows to make easier to take down & put back.
Serviced the birfs on my 80 with new rotors and pads as well......serviced the rear on my 40, non USA full floater. I've never been so :ban: greasy for so long in my life!
