What have you done to your Land Cruiser this week? (18 Viewers)
Winter temps were demanding daily use of the choke to get the 40 started and the knob was getting hard to pull. I began to fear becoming an ether junkie so I bought an repop choke cable. I should have been done in about 90 minutes but then I dropped the freakin' locknut into the black hole behind the heater box and wasted an hour trying to find it before giving up and reaching into my used hardware stash for an equivalent.
It's a close match but stands out just a little compared to the other knobs. I may have @ToyotaMatt rebuild my original (if he still offers this service) just to appease my ridiculous aesthetic sensibilities.
@numby. I get that… it’s like having a stone in your shoe…you always notice it. I’ m glad my Holley Sniper is under the hood, I can’t see it. It’s not OEM but runs damn good so it gets to stay. Spent much time and money bringing back the interior to stock. The dash pad was a big one
@sleepycruiser
Webers are VERY easy to rebuild and the kits are readily available
Which weber do you have 32/36 or 38?
32/36. I’ve watched some videos and it looks mostly straightforward.
I’ve got a 32/36 with most of the rebuild kit and a set of high altitude jets I’m looking to offload.
Need to place an ad but since y’all were talking about it.
@sleepycruiser
Was it giving issues?
I just need an overall tuneup I think. Between some idling issues and stalling issues trying to track down any gremlins. I need to do valve adjustments first, etc so just trying to gmfigure it all out.
Something that really helped with my Weber adventure was a fuel filter from an early 80’s jeep (shhh…) like this:
Kept the regular filter, put this between the pump and carb. Made a big difference.
Thanks for the tip. I need to install the original glass housing filter between the tank and pump. I just installed a new K&N glass housed filter between the pump and carb. The fuel pressure is right at 3 psi which should be where the 32/36 feels good from what I’ve read.
The filter I showed has a pressure return line, seemed to do more for the carb than the PR did. I don’t know, I was throwing whatever I could at it to make it work well. Took me to SAS, all through the mountains and back. Ran well… eventually. Then didn’t. Got tired of fussing with it.
no manual special / service orders till after the 1st of the year , and or all orders processed ........
but , ...
PM me as the NYE gets closer , i will know better then .....
- below is 2024's Gallery of Control Cables for review ... few they were , but how much passion i have for making them alive once again .... :wrench::wrench::wrench:🥼
I’ve finally found the first thing that has been a nightmare job on this thing - steering. I thought I’d refresh the original steering instead of going with a power steering setup (had been researching the fj60 swaps) since I only had a lot of play, but effort was fine. I picked up a center arm rebuild kit and a tie rod end kit from cruiserteq.
I’m a handful of tools down and 16+ hours in, and haven’t yet completed disassembly. I’ve only gotten 1 tie rod to budge, but only got about 3 turns on it before it seized back up and won’t move anymore. No amount of pb blaster, deep creep or heat will get the others to break free.
Luckily/ unfortunately, I won’t be able to work on it this weekend with sports and family Christmas activities, so I can step away and figure out my next steps.
Are you having trouble removing the nut or separating the TRE? I used this from HF and it worked like a charm.
I was able to separate the tie rods pretty easily with a similar tool (the conical version).
My issue was not enough fire for the TRE’s. 2 minutes with the torch this morning broke the threads free! I hadn’t had the flame on it but about 30 seconds at a time previously.
The issue with the rivets on the center arm bracket: not enough fire power. 2 minutes with the torch, and about 45 seconds with the air hammer...and got an action shot with the rivet flying off. Thanks for the tips! Hope this helps someone.
For those who follow my thread know I had a frame crack at the passenger rear spring hanger. @solomrus made a bracket solution inside bracket that fits inside the inner c-channel and outside gusset to strengthen the hanger area. Still stuff to be done (clean - paint - weld - paint etc)...
Also - took the grinder to my Dobinson Springs - rear for now -
Some picts of the carnage and what Rus is thinking of for a kit for others that my be in this bind.
Yellow is what was cut out - red where crack is around the hanger that needed to get patched.
This is the inside bracket - it slide in behind the inner C-Channel that was cut - the area in red is solid behind the hanger adding strength to hanger.
Here is the design for the front gusset to add strength to the overhang of the hanger to strengthen it up..
And with my Dobinsons springs - they got a whack...
took my head off for Head gasket issues. I pulled apart my valves and found somthing interesting. I think I found why my 2f decided to start drinking oil again. I just replaced all of the valve seals with oem ones. all were seated correctly. two of my valve seals were doing this....
Out of curiosity has this ever happened to you all?
My valve guides have been leaking for a while; just waiting to get my shop space back before I replace them.
When I had my 2F head refurbished in TN at Headworks of Nashville, they machined my valve guide bosses to take modern LS valve stem seals. It looks amazing and according to the shop guys will stay good for a long time, using readily available parts. I was very happy with this.
I have since sold that engine, and the bottom end began to fail for the new owner, so now that head is on a shelf at the new owner's house in case his replacement engine needs a head in the future.
I put a new fan in my rear heater. The PO had wired this with a separate switch so I had to cut the harness on the new unit from City Racer. The old one worked but would often start screeching after 30 seconds or so. I'll take it apart and see if I can clean it up.
