Nothing wrong with Bel Airs, a 9/69 Bel Air SBC powered my 40 for 21 years. The ‘72 Fleetside 350 that replaced it is great, but it’ll never be quite the same as the 350 with flat-tops, 10.25:1, dual exhaust, and an RV cam.
I rolled mine and discovered PO at one point swapped windshield frame to a glass fiber one.
Everyone is fine, cruiser will be soft top now, with a full roll cage.
I rolled my `78 fj40 back in the early 90's end over end and landed on the roof. The hard top was only held on by 4 small c-clamps temporarily and it came off. The windshield frame and roll bar supported the weight and I survived with a broken collar bone, a nasty gash to the brow and a concussion. My buddy riding shotgun tweaked his knee. That rollbar saved us, as flimsy as it is.Wow glad you are save. How your roll bur installed ? any addition support?
I wondering how strong is "original" roll bar ?
A full roll cage I understand is the only way to increase your odds in a roll over. I’m installing a factory roll bar. Did your truck have a factory roll bar? I’m using factory brackets that will be welded to underside of wheel well. While I know this is not enough, It‘s better than soft top without roll bar that I have now.I rolled mine and discovered PO at one point swapped windshield frame to a glass fiber one.
View attachment 2783516View attachment 2783517
Thank you.Wow! Glad you’re ok.
What did you have for a cage/bar? It looks like it did it’s job… although It’s done now.
As far as I was able to research my cruiser is 1983 New Zealand version: four drums, power steering, crucially NO roll bar whatsoever.Wow glad you are save. How your roll bur installed ? any addition support?
I wanted a roll cage, just postpone because I had no place to take the top of the body off. COVID made me end lease on my workshop space and for the next 2 years I won't have a place to do so. However now it's no longer my call, so I am looking for someone to do this for me locally (I'm in Poland, Europe, so no need to suggest your placesA full roll cage I understand is the only way to increase your odds in a roll over. I’m installing a factory roll bar.
That's just awesomecut out the numbers and rearranged them to give me the proper sequence and ta-da: a reasonable facsimile of my old discarded tag!
Rad! That’s a great color!!Finally spray maxed the the body with paint from Route 66 auto color. And put emblems back. All done in driveway no cover. Still need to do body work to hood and windshield and paint then have to paint the bows and waiting on the top from Julie and I’ll be done. For now
Thanks that’s the original color I went back too. Toyota 637 olive green 1976 all done in rattle can. (Spray max)Rad! That’s a great color!!
It looks great. How many coats did you apply / cans did you use? I have a very sloppy PO paint job that I’ve been thinking about working on then spraying with the spray max 2k cans to make it a little more presentable until I get a real paint job.Finally spray maxed the the body with paint from Route 66 auto color. And put emblems back. All done in driveway no cover. Still need to do body work to hood and windshield and paint then have to paint the bows and waiting on the top from Julie and I’ll be done. For now
You need to order some OEM vacuum caps, they should never wear out.Drove the 40 a good bit to run errands since things from Ida are a bit better here. Stopped to get gas and she did one of those shudder quits when I turned her off. Filled up with gas and she started up, pulled away from pump into the street, back fired, made a hissing noise and died. Would not re-fire. Thought I flooded her. Pushed her back to the gas station and spent the next 30 min trying to diagnose. Happened to walk back to the pump and found this vacuum line cap on the ground. Felt around behind carb (couldn't see it) and found where cap would have gone. Wrapped it in electrical tape, slapped the cap back on and she fired right up. Went to auto store and bought extra caps and put a clamp on it for good measure. PO installed Holley carb and removed all smog...so I assume that's why the cap is there. Drove her all weekend with no other issues.
