Many of the "portraits" I'm seeing look like filters that can be applied directly from an iPhone, or with some of the digital pic programs, aren't they?
A while back I came across this guy's face book page. I am waiting for a friend to take some good photos for me to send to him do do some drawings for me. He is ridiculously inexpensive too.
MH Illustrations - https://www.facebook.com/morne.han?fref=gs&__tn__=%2CdC-R-R&eid=ARBpfFr_r_SyEQkTCgF4-vf2FFDPHwhRtuI4CxZwsUueg554e8Rei8xtJFH_hVgax0ApVZ8Zel3rFPaa&hc_ref=ARRtxmxQlDRxypkMMNHtIgpIUNTVMMYswEIxZFVh9Gw_bJduXQcntSEfCkZZLZmLjgk&post_id=2488879778052518&dti=1761737914100045&hc_location=group
Looks like you could use a new set of shocks as well.Finished one leaf spring refresh. Pulled it all off and sand blasted it. Then chassis saver and new u bolts, anti inversion shackle, and greaseable pins.
Wow! It is the Dagha Boy indeed! Only way to tell is by the DN05RR (Dinosaur) license plate.This took me about 15 minutes.. I actually don't even know if this is your rig for sure..
PM me a couple of cool photos that you like, and I will hook you up..Wow! It is the Dagha Boy indeed! Only way to tell is by the DN05RR (Dinosaur) license plate.
Man that looks nice. Thank you!
Looks like you could use a new set of shocks as well.![]()
what is the length of the wiper blades? Wondering if they will fit my 74Installed new OEM wiper blades on my 1976 FJ40. Part number 85220-95402 for 1/75 - 1/79.
While these are 2x the cost of aftermarket, they are 4x’s better.
It looks like it’s still in primer. Is that the final color?
It looks like it’s still in primer. Is that the final color?…
I've recently switched from a Weber to the same carb you are running. I am not sure what the large inlet pipe is for, but I capped it off. I find that it fills with fuel and it is possibly causing some performance issues occasionally when the fuel sloshes around. I am not sure, but it is a hunch. What are you going to plug that up with or do you know what it is for?Mounted steering box & rolled front axle out for clean-up and rebuild.
EGRI've recently switched from a Weber to the same carb you are running. I am not sure what the large inlet pipe is for, but I capped it off. I find that it fills with fuel and it is possibly causing some performance issues occasionally when the fuel sloshes around. I am not sure, but it is a hunch. What are you going to plug that up with or do you know what it is for?
