This is gold. Can you elaborate more on when the rings will no longer seat and none of this will work? I did the long pulls, my compression has steadily gone up. Rig is parked until I can reseal this header for the 4th time. Vacuum leak is an issue!There are tricks that can be done to get rings to seat better. One is to pull long hills in almost too high of a gear, not quite lugging, but almost. Then, engine brake down the same hill in *almost too low of a gear, letting the engine slow the rig down.
I've also seen a pinch of AJAX powder or Bar Keeper's Friend cleaning powders being dropped into a spark plug hole, used as a mild abrasive which will let the ring and cylinder surface get a better seal once worn in a bit. The powder will be cycled out of the motor and will leave through the exhaust, and won't harm anything.
These are old tricks from long dead hot rodders I knew in a different life, but they've worked for me in the past.
As always, read up on it yourself before you try stuff. But it could save you some labor if it works for you. Worst case scenario, you end up pulling it apart and replacing rings anyway.
Thanks for this old time advice and may it never die…
Dan
