What have you done to your Land Cruiser this week? (49 Viewers)
Replaced my spark plugs with some Denso W14EXR-U plugs, embarrassed I didn’t do it sooner after seeing what they looked like. Any cause for concern here or is this normal for old plugs?
Split the difference between the recommendations I saw and went with a gap of 0.035” (coil is aftermarket). Also adjusted the choke on the Weber, between those two things the 40 is running like a top again! Wasn’t bad before but had gotten a little slow to start and idle felt rough.
***Update** Just took the 40 for a quick spin around the neighborhood, holy *%#@! It’s like a completely different vehicle, feels like it’s got 50 more HP and so much smoother. I’m still embarrassed I haven’t done this before now but will never make that mistake again!
This took me about 15 minutes.. I actually don't even know if this is your rig for sure.. :)
Wow! It is the Dagha Boy indeed! Only way to tell is by the DN05RR (Dinosaur) license plate.
Man that looks nice. Thank you!
PM me a couple of cool photos that you like, and I will hook you up.. :)
Another Unicorn is all grown up leaving the pasture ….
But with a complete set of all NEW gear to help it along ..
- UV rated black connector plug and solid brass yazaki japan terminals extra one for practice too of course
- B+ ring terminal a thicker guage of brass then stock !
- over engineer it and it will out live you !
- B+ ring terminal black rubber Yazaki japan rubber weather and safety boot
- red yazaki F. E. N. Plug / Connector weather boot !
a total plugs and plays included a top lock down OEM wide washer toyota special service japan bolt …
Well, YEAH - how's she gonna compete with that red hot weather boot?
Mounted steering box & rolled front axle out for clean-up and rebuild.
I've recently switched from a Weber to the same carb you are running. I am not sure what the large inlet pipe is for, but I capped it off. I find that it fills with fuel and it is possibly causing some performance issues occasionally when the fuel sloshes around. I am not sure, but it is a hunch. What are you going to plug that up with or do you know what it is for?
EGR
