Target carrier
Really looks good. Did you cut the rockers out already? Good idea to get that area cleaned up before welding in new.
Yes I cut the rockers off and had him blast out anything that wasn't solid. All and all the biggest surprise is how little he uncovered, I was bracing myself for some unpleasantness under the five coats of paint.
Looks great. Your skills are awesome!:)
Thank you!:beer:
Sweet! One thing I always wonder is what people do underneath repairs...
What will you do inside the rockers? Will you use weld-through primer on the inside of the replacement rockers?
I will use SEM 40783 Copperweld on all the lap joints then after everything is welded I have a special snout nozzle for my pressure pot that will let me paint inside all the enclosed areas, it basically a ¼” copper tube for the air with a 1/8” tube on the inside for the paint and I have a few different lengths. I will encapsulate everything with two coats of marine grade epoxy primer then two coats of a polyuria that’s basically a catalyzed rubber membrane.
I'll try to get pictures when I get to that part.
I would like to thank Pighead for the tip on using the front finder lip to fix the rear, if we ever meet I owe you a beer :beer:
For the bottom I had to build a new inner and outer panels from .080” steel
Beautiful work. Nice for the rear fender, not so nice for the front one.
I really like your custom air box page 15. It is inspirating.
Looks awesome! Wish I had your welding skills!
Thank you!
Thank you!
Every damn page is inspiring! Good job, Man.
Thank you Ron! Reading your build thread inspired me or cursed me into going further on this one.
I thought Toyota had one disgruntled engineer working at the time these 55’s were designed and he worked in the electrical/wiring division apparently they had two disgruntled engineers working at the time these things were designed and the other worked in the body division.
When I make a repair panel I always try to duplicate what the factory did and working on this rust repair has forced me to take a closer look it this abomination. If they set out to build a body to fail then they hit the nail square on the head, if they set out to build a body that was drivable on paved roads then they failed miserably, if they set out to build a body that could be driven off road in dirt and water and not rust from the inside out then some cruel engineer played painful joke on Mr. Toyota.
For Pablo.
This is the process I’m using for my rust repair.
I scrape and wire brush the rusty area then chemically kill the rust, prime with epoxy primer then seal with epoxy paint, the copper color strip is a weld primer on the lap joint.
After everything is welded I will shoot more epoxy through the openings.
For Pablo.
That's my plan also. Drill few holes where necessary and shoot in 3M rust fighter then plug holes.
http://3mcollision.com/products/coatings/3m-rust-fighter-i-08891.html
You may have gone over it before, and yes I know there are a ton of opinions and write ups on paint....
but, If you don't mind me asking what epoxies have you settled on?
I was going to use DuPont Imron industrial coatings but I settled for Acrolon because I think it’s a bit more durable and the system I’m using should offer better future rust protection.
Recoatable Epoxy Primer B67 SERIES for the primer, it’s a marine grade primer that should offer years of protection and it has a longer recoat time than most epoxy primers.
http://www.paintdocs.com/docs/webPDF.jsp?SITEID=STORECAT&doctype=PDS&lang=E&prodno=B67A5
Acrolon 218 HS Acrylic Polyurethane for the top coat, it very durable for a paint and looks better than a bedliner coating on the outside.
http://www.paintdocs.com/docs/webPDF.jsp?SITEID=STORECAT&doctype=PDS&lang=E&prodno=B65B600
Thanks!
I have been planning to use Imron as well. I'll look into the Acrolon.
Acrolon 218 allows for double the dry film build and has better ratings across the board, especially Impact resistance.
JMack, any chance you could shoot me the files for your engine mounts and cross member? I'm going to see in my guy can use them. Do you have an nv4500 behind your cummins?
