RED on the Head like!!! (3 Viewers)
Died in town
We're ready Bob....
iu
I'll just keep changing filters.
Try this Fuel Filter
Amazon-- PQYRACING AN6 Inline PQY Fuel Filter E85 Ethanol With 100 Micron Stainless steel element.
They are around $30 and they interchange with the Areomotive filters.
It has a large filter element with lots of surface area that's going to help you.
Will give it a Shot 1(not .45 but try it.) Using Aeromotive 100 micron pre fuel pump 😉 so it's working by saving the pump 🧐🤔. Found out Ethanol even low 10% will turn yellow Egg 🍳🥚 yolk like in less than 30 days WTF. Just keep duming fresh gas in and running will help until fuel runs clear. I think putting 10 gals in today stirred da 💩😳😲😉🧐🤔🤣🤣
Throw a couple of cans of Sea Foam in the tank. Unlike Stabil, it will mix with the gasoline and help stabilize the ethanol. Stabil just floats on top to act as a barrier to the air. Both help but work completely differently.
Ethanol is fine and will soak up water/moisture as long as there isn't too much water. As soon as the water percentage gets too high the ethanol/water mixture separates from the gasoline - that's when you have a problem.
I like being able to see inside the filter, but that is not always an option!
Do you have any ethanol free options out there?
Recomended tourque is 40 lb . Anymore pump is damaged. I tightened everythinhg and ,crawled under and seems O.K. Found somee other ****ed up 💩 I'll elaborate on tommorow 🧐🤔😉
If it was easy everyone would be doing it Bob, but yeah it sure seems to be putting up a fight :worms:
