Try this Fuel FilterI'll just keep changing filters.
Throw a couple of cans of Sea Foam in the tank. Unlike Stabil, it will mix with the gasoline and help stabilize the ethanol. Stabil just floats on top to act as a barrier to the air. Both help but work completely differently.Will give it a Shot 1(not .45 but try it.) Using Aeromotive 100 micron pre fuel pumpso it's working by saving the pump
. Found out Ethanol even low 10% will turn yellow Egg
yolk like in less than 30 days WTF. Just keep duming fresh gas in and running will help until fuel runs clear. I think putting 10 gals in today stirred da
I like being able to see inside the filter, but that is not always an option!Try this Fuel Filter
Amazon-- PQYRACING AN6 Inline PQY Fuel Filter E85 Ethanol With 100 Micron Stainless steel element.
They are around $30 and they interchange with the Areomotive filters.
It has a large filter element with lots of surface area that's going to help you.
Do you have any ethanol free options out there?Will give it a Shot 1(not .45 but try it.) Using Aeromotive 100 micron pre fuel pumpso it's working by saving the pump
Pump leaks?Fuel ump leaks and try to start get 1 click WTF. Started fine last night turn key no gas and starts WTF .
6 bucks a gallon. Gonna rip all this crap out and go back mechanical pump and Toyota fuel filter. Incoming order for @cruiseroutfitDo you have any ethanol free options out there?
No. Fittings leaked and plate on bottom of pump screws not even tightPump leaks?
Did you have a lot of water in the fuel that then froze?
Reseal the fittings and tighten the screws!No. Fittings leaked and plate on bottom of pump screws not even tight
X2Reseal the fittings and tighten the screws!
If it was easy everyone would be doing it Bob, but yeah it sure seems to be putting up a fightRecomended tourque is 40 lb . Anymore pump is damaged. I tightened everythinhg and ,crawled under and seems O.K. Found somee other ****ed upI'll elaborate on tommorow
Landcruiser lifeit sure seems to be putting up a fight
