bump?
Sorry for the delayed response. Been a bit crazy lately and haven't been on in a while.
For the 14 Bolt I found that the long side (passenger) shaft on a factory axle is right about 6" longer than the factory short side (driver). For the housing to be offset and re-use the factory shafts, the long side now has to accommodate a shaft that is 6" shorter and the short side now has to accommodate a shaft that is 6" longer.
For my setup I measured 4" back from the back of the backing plate flange on the short side and 10" from the flange on the long side. Swap the tubes side to side and the shafts will swap over no problem.
updates?
Bump?
That I don't know, I would have to go back through the thread. Freds40 is no longer in 4wd last I heard, he has a hot rod now.
